Trying to load Spiderman svcd to convert to DVD and I get a 'Can not open or unsupported' error message in TMPGENC. WMP will not play it either. Tried all of that Environmental settings in TMPGENC stuff but still no luck. Do I need a new codec or something? plz help!
Try the MPEG-2 VFAPI pluginb for TMPGEnc.
http://e3lt11.ocv.ne.jp/mpeg2/
Then increase the priority of the plugin. Or simply create a dvd2avi project of the MPEG-2 and load the *.d2v into TMPGEnc. -
loaded the plugin. tmpgenc accepted it this time. i went to merge tools and loaded the mpg and did a edit. i scrolled the the movie and everything was in synch. does that mean the encoded version will be ok also?
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 14:58 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46
