I have discovered how to trick the anti-copy of the SAMSUNG SV-DVD1E, and to
let effect his copy even if protected,
but....
not as to disable the macrovision :(
the sequences that you had sent me transform him/it in multiregion, but they
don't disable the macrovision...
do you know how to do?
the dvd is a dvd-vcr, the copy is effected, but the macrovision lets jump
the image...
p.s.:I don't speak English, you excuse the imperfections.
Mat
You can't disable Macrovision with a hack. There maybe a hardware modification you can do, but the easiest way I've found is to use a Macrovision removing scart lead, connect it between the two scart sockets and set the video section to record from the Aux input (scart socket).
Hope this helps! -
better that nothing ;-)
at least I don't have to buy me another vcr
other firmwares?
changes easy hardwares?
thanks equally =:-)
Mat
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
