Why VCD have a lower bitrate of 1374 kbps than audio CD? I canot understand that because both hold 80 minutes of content.
Results 1 to 11 of 11
Two reasons.
1. There must be room for the video and other files
2. The compression of audio CD and the audio part of a VCD is different. The former is uncompressed LPCM and the latter is compressed Mpeg.
Your 1374 kbps is wrong. The max is 384 kbps.
Assuming, of course, we are both talking about a Video CD. Does VCD stand for something else as well ? -
Huh?? 1150 + 224 = 1374
What is the difference it is a 320 kbps Mp3, ogg, h265, mpeg2 or wav file? -
vcd has to allow for things like closed captions, multipexing overhead, etc. mp3, ogg, h265 and wav are not allowed by the vcd spec.
Like any container format (yes, even modern ones such as MKV and MP4), the file size is larger than the sum of the elementary video and audio streams. It's called overhead and it's where the "missing" bits come from. Audio CDs don't have that.
Edit: More like this but don't quote me on the total bitrate (1411):
1150 + 224 + 37 = 1411
Where is your 1440 kbps actually coming from? I don't recall that number.Last edited by Skiller; 23rd Sep 2021 at 19:54.
Additionally the quite old Audio-CD-(low-level-)format hasn't got the same redundancies for error correction as later digital formats.
Audio on audio CD = 16bit, 2ch, 44.1kHz. 16 * 2 * 44100 = 1,411,200 bits/sec or 1,411.2 kbps (if using 1000base). Or 1,378.125kbps (if using 1024 base). The actual disc data bitrate is slightly higher because of presence of subcode, and this ALL has reed-solomon error correction, so 1500 is an easy round number to remember for the 1x CD overall data rate.
Something tells me that you aren't into rounding, though.
Scott -
What nonsense.
Don't feed the trolls. Learned this back in 1997 in newsgroups.
Downloading from BBC Sounds 320 kbps - youtube-dl
By CodeQ in forum AudioReplies: 0Last Post: 29th Nov 2019, 18:55 -
I Upconverted 124 Kbps MP3 to 320 Kbps and it Sounds Better. Why?
By pone44 in forum AudioReplies: 10Last Post: 22nd Jun 2019, 19:25 -
320 Kbps MP3 music file edit question
By VEBouto in forum AudioReplies: 2Last Post: 23rd May 2019, 19:20 -
What is better DTS Core @ 1509 Kbps or AAC @ 700-1000 Kbps from DTS-HD MA
By vash1 in forum Newbie / General discussionsReplies: 5Last Post: 14th Nov 2018, 12:29 -
audio bitrate via Audio Track in Play drop is different
By kelvin.shee in forum Software PlayingReplies: 5Last Post: 2nd Oct 2017, 05:09
