  1. There's something I'm wondering about subme 11
    It's said that subme 10 requires trellis 2 and aq-mode>0 but since it's not specified for subme 11, does it means that it needs it as well or no ?
    HTML Code:
    - 10: QP-RD - requires trellis=2, aq-mode>0
    - 11: Full RD: disable all early terminations
    Thank you
  2. Yes, every higher level of some setting encompasses everything from the lower level and adds to it.
    That said, subme 11 is a "placebo" setting and honestly, it adds significant encoding time for little to no improvement of quality.
  3. Originally Posted by sophisticles View Post
    Thank you for your concise answer.
