Hi my parents DVD player is not working I tried changing the batteries but still nothing and I've also tried resetting the codes but still nothing.
Welcome to the forum. I hope you find the answer you need.
Sent from my iPad using Tapatalk Pro -
you might try to power cyce the device. Unplug from the AC mains for like 10 minutes or so. Does the unit have a power button on the FRONT panel ? if so press that for 20 or 30 seconds while it is unplugged. after 10 min plug bakc in and see if it will power up? You need to tell use more information if you want help. Like when you say its not working what do you mean ? like the remote not turning it on? more details
If the remote is a standard infra red one, you can easily check if it is the remote or the player. Open the camera app in your phone, look at the sender end and press a button. The camera can see infra red while the eye can't, so if it is working you'll see the sender in the remote flashing while a button is pressed.
Sony rdr-hxd870 dvd recorder passthrough
By DMS in forum Capturing and VCRReplies: 22Last Post: 4th Jul 2021, 15:52 -
SONY DVD/VCR stopped working RDR-VX560
By tsheridan in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2021, 17:51 -
Passthrough for Sony DVD Recorder RDR-HXD 870-970-1070
By themaster1 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th Mar 2018, 15:49 -
Sony RDR-HXD890. DVD+/- RWs : Format Failed.
By Mr Mooney in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th Sep 2017, 16:53 -
DVD Problem with Sony RDR HXD710
By bahjan in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd May 2017, 19:56
