    Nov 2019
    Buenos Aires, Argentina
    Hi,
    I do not have a preview image while capturing DV in Adobe Premiere Pro 2021. I also do not get an image before I start recording.
    If I have direct sound at all times.
    Captures are successful even if you don't have a preview.
    I have the preview options activated during capture.
    Any solution? I see that it happens to a lot of people but I could not find the solution. I would like to be able to preview since the material I am capturing is of interest to me, and it would save post-viewing time.
    Thanks!
    Jan 2016
    As suggested in the other thread use Sc-live. DV is not capture although Premiere may think so, It is a file transfer 1:1 and bit by bit, except that it is in real time due to the limited bandwith of the firewire port.
    Nov 2019
    I am using ScenalyzerLive 4.0 and I get a preview of the capture, it just doesn't seem fluid, I would like it to be a more real visualization in terms of fluency but better than nothing. Thanks
    My preference for Premiere is because then I use it directly to export compressed files in H.264, but I can still do it with the Encoder.
