    Aug 2010
    Westchester NY
    just curious in terms of quality, which of these brands make hiugher quality pc burners?
    my lg and asus are not working and purchased a pioneer drive. I liked that it came in the box vs buying the lg and asus which they simply handed the bare drive as is.
  2. Lg and Asus are the same from my understanding
    just re branded, also i purchased my Asus from microcenter and it came in a box.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Had LGs all of my life. Couldn't find one local when I needed one so bought an Asus.....works perfectly.
    Aug 2006
    Pioneer has a better reputation than LG. However, Pioneer internal Blu-ray drives are a little longer than a standard optical drive and may not fit inside external 5.25-inch optical drive enclosures or small computer cases. (I've owned both brands.)
  5. Originally Posted by usually_quiet View Post
    Can your Pioneer play 4KUHD
