Results 1 to 30 of 35
  1. Hello
    I tried everything to download the files from this link.
    I have the keys to decrypt them so I need just to download the encrypted ones.
    Nothing I am aware of is working.
    Here is the link to the manifest file:
    Click here
  2. < Nothing i am aware of is working.... >
    you have try yt-dlp?
    yt-dlp --allow-unplayable-formats https://level3cdn.hbogo.eu/714f7e74-f422-45aa-bc21-510837e9e6b1_hbo/COMP/138447453_bul_comp_2c177faf-f633-4c86-8594-fefd653b6c81_3400000_v2.ism/manifest
  3. HBOGO.EU might require some additional work.
  4. Originally Posted by lomero View Post
    Yes I did. The result is not-decryptable file, both video and audio plus the audio cannot be downloaded fully - it outputs an error "ERROR: argument out of range"
  5. Originally Posted by [ss]vegeta View Post
    that's what I thought too.
  6. you write: I have the keys to decrypt them so I need just to download the encrypted ones.
    if you have key, use my code, download and decrypt.... what's the problem? don't understand.
    or with your key don't decrypt?
  7. Originally Posted by lomero View Post
    the files don't decrypt because they're damaged.
    I don't have any problems with other sites.
  8. Here they are the keys
    try to download and decrypt the files
    KID: 0a8b0568348abec07fb4b45d242dffc0
    Key: e47189e571eda2e23686319f11ea20fb
  9. wrong key?
    write video link
  10. Originally Posted by lomero View Post
    wrong key?
    write video link
    It's in the first post
  11. this is manifest link. need VIDEO link (to get key and download mpd)
  12. Originally Posted by lomero View Post
    You'll need a Bulgarian VPN and my account to do that. HBO GO is geoblocked. But if you think you can access it I'll give the credentials to you in PM.
    Feb 2006
    try using streamfab for HBOgo - https://www.dvdfab.cn/hbo-downloader.htm?trackid=headmenu2
  14. Originally Posted by october262 View Post
    They are not working with HBO GO, although they say it is supported in fact it isn't. HBO Europe is HBO Nordic actually. Via their browser I was able to login only to realize the video cannot be played (it issued an error saying "There was an error during playback. This video cannot be played". In short - crippled software.
    Jan 2021
    Argentina
    Did you get that key using w******e guesser? Because the manifest says that the files are encrypted with PlayReady DRM.
  16. Originally Posted by lfer94 View Post
    Did you get that key using widevine guesser? Because the manifest says that the files are encrypted with PlayReady DRM.
    Yes indeed with the guesser.
    Are there other tools to download/decrypt PlayReady DRM?
  17. try to write here your video link.
    for VPN no problem.
  18. Yes indeed with the guesser.
    https://github.com/xhlove/XstreamDL-CLI/issues/11
    https://github.com/xhlove/XstreamDL-CLI/issues/14
    Jan 2021
    Argentina
    The only tools to download encrypted content that I know of are yt-dlp, XstreamDL-CLI and N_m3u8dl-CLI. mp4decrypt is able to decrypt PlayReady, but you will can't if don't have the proper key.
  20. Originally Posted by lfer94 View Post
    Just because it has playready pssh in manifest does not necessarily means it is Playready DRM protected. Widevine pssh can also be derived from playready pssh.
    Chrome on Windows supports only widevine if hbogo can play DRM video protected, they are definitely widevine DRM protected. This is why extension gives keys for Playready protected manifest. Edge chromium based browser however supports both widevine and Playready.
    discord=notaghost9997
  21. Member godai's Avatar
    Oct 2012
    United States Florida
    sorry for offtopic please
    N_m3u8DL-CLI , it can be used on tvheadend like ffmpeg or streamlink?
  22. Originally Posted by lomero View Post
    for VPN no problem.
    I have sent you PM with the credentials and the direct link.
    Please do not post them here or you will get me in big troubles.
    You cannot play the video unless you are logged in so it's useless to write down the video link here in the forum.
    HBO GO are professionals, not just some lousy amateur driven site.
    p.s. There are 5 devices logged in limit. Please do not try to log in from many browser/ips for you will lock my account and I'll have to call them to unlock it.
  23. Originally Posted by notaghost View Post
    Thank you for your prompt answer.
    I guess the only problem is with downloading the encrypted files. They are garbled so the decryption cannot be done. Using yt-dlp gives one non-decryptable file /possibly because it is damaged/ while XstreamDL-CLI produces file(s) which cannot be decrypted (the output size is 0). N_m3u8 simply doesn't work. So we need only the good PlayReady encrypted files downloader.
    And yes, HBO GO is widevine DRM protected for sure, otherwise the extension simply wouldn't work and definitely won't be showing any keys in the console tab.
  24. Member
    Jan 2021
    Argentina
    I get it. Thanks for the clarification.
  25. So is there a solution? I think the problem is with the downloader.
    Here you can try with a smaller file, only a couple of minutes long
    KID: 8d711528435707374d66ed55cbb27d2c
    Key: c3f35dfd75dbe89cbfda4e65b91fb310
    yt-dlp --allow-unplayable-formats https://akamaicdn.hbogo.eu/69ac5015-506d-157e-1b62-2a0c0e403875_m127883_hbo/COMP/141027740_bul_comp_2c177faf-f633-4c86-8594-fefd653b6c81_3400000_v2.ism/manifest
  26. So is there a solution? I think the problem is with the downloader.
    https://github.com/xhlove/XstreamDL-CLI/issues/11#issuecomment-892144654
  27. Originally Posted by karapuz View Post
    There's so much you can cover with "manipulating the javascript in network tab".
  28. Originally Posted by karapuz View Post
    it is simply not working.
    The produced files cannot be decrypted. mp4decrypt produces 0 bytes size files both for the chunks or the whole concatenated file both by "copy /b *.mp4 encrypted.mp4" or by using the "--raw-concat" option.
  29. 1) download with yt-dlp
    2) change init segment with these segments
    https://siasky.net/EAD5aELgEi-5x-PNtEOEaS90rGwSimRiq103cdTclz7VOw
    3) decrypt with keys
  30. Originally Posted by notaghost View Post
    with these segments
    How do you get the proper inits?
