As a musician, I often use compressor limiter devices and software, but for audio only. But I was wondering it there is any software to compress-limit the audio volume of videos, movies, etc. I would like to have a constant audio volume output without the ups and downs that often occurs. Thanks in advance.
You just separate the audio, use the tools you're familiar with, then put the new audio and video back together
Dynamic range compression can be done at playback for instance by enabling the corresponding win10 sound Enhancement.
VLC also has some built-in audio filters which can be applied. -
Avidemux or mkvtoolnix GUI is MKV is suitable
MKVToolNix for MKV. ffmpeg (command line tool) for most other containers. ProWo's Clever ffmpeg GUI for a GUI for ffmpeg. It might even support ffmpeg's audio acompressor filter so you don't have to demux/remux separately.
https://ffmpeg.org/ffmpeg-filters.html#acompressor -
Audio hard limiter quality
By qo4on in forum AudioReplies: 19Last Post: 29th Dec 2020, 23:44 -
best video compressor/convertor
By natty in forum Newbie / General discussionsReplies: 26Last Post: 13th Nov 2020, 10:06 -
Help to Find Best Video Compressor
By Yamiraan in forum Video ConversionReplies: 4Last Post: 8th Nov 2020, 16:45 -
Magix NLE, audio clipping according to Audacity, even with limiter
By abolibibelot in forum AudioReplies: 2Last Post: 7th Jan 2019, 12:53 -
How to insert video as window/frame in another and keeping both audios?
By dvdboy2 in forum EditingReplies: 1Last Post: 24th Nov 2017, 08:48
