For data recovery purposes (more precisely : to sort out files recovered through “raw file carving” which are in fact parts of valid files successfully recovered through filesystem based recovery — or similar situations), I would need a command line program, or a PowerShell code, that would compare two files, starting from a specified offset, usually different for each file (usually those are small files contained within bigger files — for instance a MPG file which starts as part of a valid VOB file, but which continues with fragments of other files, and may contain fragments not belonging to any file that was still registered in filesystem structures at the time of the recovery), until the first difference is found, and simply report the offset of the first difference, reliably and quickly. I've already asked this at SuperUser, but didn't get a usable solution. The only existing tool I found which apparently does exactly what I need, “cmp”, is part of (as I understand it) an obscure IBM industrial-level operating system, and doesn't exist as a standalone executable.
An alternative method would be to calculate checksums of partial areas in files of a specified size, then report matching areas ; for instance, set the area to 1MB, calculate the MD5 for each MB of each processed file, store them in a temporary list, then report all areas that have been identified as identical. (WinHex has a feature called “block-wise hashing and matching” which I hoped would work for this task, but it turned out to be totally impractical — details in the aforementioned SuperUser thread.)
If not here, where could I ask something like this with a good hope of getting satisfying replies ?
Results 1 to 1 of 1
Video files: Report list of media types with attributes?
By Frasier in forum ComputerReplies: 0Last Post: 18th Sep 2021, 21:42 -
Program to compare 2 video files to see results of restoration?
By VidNew23 in forum RestorationReplies: 15Last Post: 6th Apr 2021, 23:54 -
how to compare parameters of video files
By kuku in forum Video ConversionReplies: 41Last Post: 21st Feb 2021, 07:22 -
Compare 2 video files for 'cut' differences
By kolipri in forum EditingReplies: 5Last Post: 20th Dec 2020, 22:29 -
batch that compare filename in 2 folder
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2017, 04:58
