Hello, dear all.
---> https://www.youtube.com/watch?v=4c2-at5Mr3I&ab_channel=JohnBrzenk
For the video above ( or similar ones on Youtube) , does it possible to get the automatic generated subtitles using some program?
When I use Tubedigger or or IDM I can't "see" the subtitle "stream" on this link.
This programs can download Ok the videos. But not the subtitle "file".
---> https://www.youtube.com/watch?v=KrI9W39xlLQ&ab_channel=LevanSaginashvili
In the other link above, it seems that does indeed ( in this example ) exist some " VTT" subtitle file as a stream. And using IDM or Tubedigger ( and many others too ) we can get video + audio + subtitle just fine.
For those videos that do not have any VTT ( or similar files ) available on Youtube, does exist a way to grab the subtitles that are automatic generated by Youtube engine itself? And not only to grab the text, but the timing from all the speeches, just like any movie subtitle files?
Thanks for your time.
Best regards.
Hi, dear all.
@ Nilzzon
Hi. Thanks for your tip!
I could test 3d youtube downloader. I used the portable option available and did some tests. To see how the program works, how the settings / options works.
I could download the automatic generate subtitles! Very nice program ! I never knew that this could be done using some specific program!
I could find some information about the subject. Some online sites can help with that subtitle grabbing too.
---> https://stackoverflow.com/questions/15000659/is-it-possible-to-download-the-automatic-...s-from-a-video
---> https://www.quora.com/How-do-I-download-auto-generated-subtitles-in-YouTube
---> https://www.diycaptions.com/
The subtitles must be polished concerning about the timing. But it helps a lot!
If you know other programs ( freeware, if its possible ) than can do that, you can point here.
Thanks again for your help and time!
Best regards.
question how to download subtitles/cc using youtube-dl from this link
By jimdagys in forum SubtitleReplies: 6Last Post: 22nd Feb 2022, 10:25 -
Colored Subtitles for YouTube?
By karabiner99k in forum Newbie / General discussionsReplies: 0Last Post: 14th Apr 2020, 05:04 -
how i can let scrolling subtitles in youtube show in desktop by same effect
By atonvision in forum SubtitleReplies: 0Last Post: 6th Jul 2017, 08:16 -
Is it possible to grab videos off Youtube from a selected trim timeline?
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 17th Jan 2017, 05:08 -
How to capture youtube video along with the subtitles
By kasfig in forum Capturing and VCRReplies: 3Last Post: 14th Jan 2017, 14:36
