Hi,
my family bought a Video8 camera back in the early 2000s, and I'm currently capturing the contents of the old tapes recorded with it. The camera was used up until it's death in 2010, and by then new Video8 tapes became practically impossible to find, so at around 2005 we started using Hi8 tapes to record on.
I have successfully digitised the recordings on Video8 tapes using a Video8 camera I recently purchased used, however it doesn't read the Hi8 tapes even though they were recorded on with a Video8 camera. When I play them, I only see static (like the one on an empty Video8 tape).
Could the tapes be empty or is this some problem of the camera? From what I've seen online Hi8 uses a different material for the tape compared to Video8, is this true and if yes, could this be the issue?
Are you sure the tapes have V8 recordings? Static is a symptom of D8 put in an analog camera.
Yeah, I'm pretty sure, since I was the one who made the recordings onto Hi8
I believe I mentioned in an earlier topic that most Video8 camcorders do not record/playback Hi8 tapes.
There were exceptions so I guess your original camcorder was one that did but your recent purchase does not. -
I tried recording on one of the Hi8 tapes with the recently purchased camcorder, and it recorded to the Hi8 tape just fine though.
You also mentioned that you have a D8 camera so do consider our friend's response.
Could you possibly have recorded with the D8 camcorder and your memory has deserted you ?
Try the tape in that camcorder. -
Hi8 camera doesn't play Hi8 well, only plays Video8 well.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Jun 2020, 16:10 -
Hi8/Video8 to Digital/DVD
By Anon45 in forum Newbie / General discussionsReplies: 12Last Post: 12th Mar 2018, 18:50 -
Can I record Hi8 quality on video8 tapes?
By chinhang899 in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2017, 04:00 -
Capturing Video8/Hi8
By pvrbulls in forum Capturing and VCRReplies: 13Last Post: 12th Feb 2017, 09:31 -
Hi8/Video8 Conversion Questions (Help Wanted, Please!!)
By RyfromNy in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 12:45
