Hi everyone,
new to FFmpeg and muxing remuxing stuff.
I have Qoocam 8K 360 camera which creates MOV container with 2 video tracks and 1 audio track. Camera also, presumably, creates metadata with on board sensors for stabilization and orientation purposes (perhaps even more proprietary data).
I own Video Enhance AI software from Topaz Labs and I would like to:
1. extract both video tracks
2. enhance quality of those tracks (in Video Enhance AI)
3. replace those two video tracks in original MOV file
4. Stitch in Qoocam Studio to create equirectangular enhanced video file.
Is there any other way to achieve better AI quality of the video?
Enhancing stitched equirectangular footage creates artefacts at nadir and zenith areas because Topaz Labs products are not 360 aware.
extracting all tracks:
ffmpeg -i in.mov -c copy -map 0:v:0 out_0.mov
ffmpeg -i in.mov -c copy -map 0:v:1 out_1.mov
ffmpeg -i in.mov -c copy -map 0:a:0 out.wav
combining tracks together (metadata is missing in Qoocam Studio error), this way the file isnt recognized in Qoocam Studio:
ffmpeg -i Q360_20201108_135512_000000_track0.mov -i Q360_20201108_135512_000000_track1.mov -i audio_0.wav -c copy -map 0 -map 1 -map 2 output.mov
Code:General Complete name : V:\Qoocam 8K remux video test 02\Q360_20201108_135512_000000.MOV Format : MPEG-4 Format profile : QuickTime Codec ID : qt 0000.02 (qt ) File size : 41.4 MiB Duration : 1 s 67 ms Overall bit rate : 326 Mb/s Encoded date : UTC 2020-11-08 13:55:14 Tagged date : UTC 2020-11-08 13:55:14 Writing application : Lavf57.56.100 Video #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L6@Main Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 1 s 67 ms Bit rate : 110 Mb/s Width : 3 840 pixels Height : 3 840 pixels Display aspect ratio : 1.000 Frame rate mode : Constant Frame rate : 30.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.248 Stream size : 14.0 MiB (34%) Language : English Encoded date : UTC 2020-11-08 13:55:14 Tagged date : UTC 2020-11-08 13:55:14 Color range : Full Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : hvcC Video #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L6@Main Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 1 s 67 ms Bit rate : 119 Mb/s Width : 3 840 pixels Height : 3 840 pixels Display aspect ratio : 1.000 Frame rate mode : Constant Frame rate : 30.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.268 Stream size : 15.1 MiB (36%) Language : English Default : No Encoded date : UTC 2020-11-08 13:55:14 Tagged date : UTC 2020-11-08 13:55:14 Color range : Full Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : hvcC Audio ID : 3 Format : PCM Format settings : Little / Signed Codec ID : sowt Duration : 1 s 46 ms Bit rate mode : Constant Bit rate : 1 536 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Bit depth : 16 bits Stream size : 196 KiB (0%) Language : English Default : Yes Alternate group : 1 Encoded date : UTC 2020-11-08 13:55:14 Tagged date : UTC 2020-11-08 13:55:14
[SOLVED] [VSDC] Keeping only parts of a video track?
By yetanotherlogin in forum EditingReplies: 3Last Post: 18th Apr 2020, 08:05 -
Process for keeping track of progress of watched video files
By mr-scarface in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2020, 18:27 -
Batch replacing video file with a different audio track
By Restricted in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2017, 07:30 -
replacing (and syncing) an audio track of an MP4 video file
By rotchild in forum Newbie / General discussionsReplies: 6Last Post: 23rd Dec 2016, 05:32 -
replacing (and syncing) an audio track from an MP4 video file
By rotchild in forum RestorationReplies: 0Last Post: 14th Dec 2016, 21:30
