I ordered a small amp for 2 bookshelf speakers for the pc but till it comes in, im using this tiny laptop bar that sits on the edge of the monitor. there is no sound thhere. I cant find a way to amplify the sound or use some equalizer?
any help please?
stay safe
	If there is truly NO sound amplifying it won't help. 0 x N is still 0.
 How is that sound bar connected to the laptop? USB only? If so, you probably just have to set the audio output device to that USB soundbar. Right click on the speaker icon in the Tray and select Open Sound Settings. Set the Output to the soundbar.
	@Nilzzon
 worked perfectly. thank you for that!
 @jagabo
 yea, usb. having some issues with the drivers and audio output connector isnt working so got a usb speaker for now. thank you
  sync offset and jitter values in mpc-hc and mpc-beBy Milardo in forum Capturing and VCRReplies: 0Last Post: 16th Nov 2020, 19:29
  How to amplify voice to make it sound like a large sound stage?By ikevin8me in forum AudioReplies: 2Last Post: 7th Nov 2020, 15:40
  Question about AC3 Filter with MPC to increase sound when playing aviBy jimdagys in forum AudioReplies: 3Last Post: 13th Jan 2019, 17:50
  Hearing this odd chirping type sound during MPC-HC playback.By Darkmatter in forum AudioReplies: 15Last Post: 24th Jul 2018, 04:29
  How to amplify the sound of my speaker?By Meghanmax in forum AudioReplies: 3Last Post: 22nd Apr 2017, 11:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
