I want to connect an audio source to the input of the sound card, and be able to hear that audio on the speakers connected to the output of the same sound card. How can I achieve that routing of sound in Windows XP? Thanks!
Results 1 to 14 of 14
Virtual cable routing, using something like voicemeter or its family of products.
Scott -
Thanks, would you be referring to this program? https://vb-audio.com/Cable/index.htm
Yes, there are a variety with progressive capability/complexity, some freeware, some donation ware, some payware. Read up & pick the one(s) that suit your needs.
My quick guess is you may just need the free cable pair, but the expanded capabilities of the virtual mixers are very attractive.
Scott -
Only with certain kinds of inputs and outputs. And it isn't nearly as flexible.
Example: I have a voicemeeter config where I have
1. Mic input, with EQ
2. 2nd mic input from wireless mic, w noise gate
3. Line input from guitar A/D box
4. Output from spotify/wmp, etc rerouted to 2nd line input (as bkgd music)
5. Output 1 is mix of 1,3,4 and goes to headphones, with optional mix-minus
6. Output 2 is mix of 2,3,4 and goes to speakers
7. Output 3 is a different submix with diff levels that goes specifically to Zoom
8. There is a separate recorder than can record any of those outputs (to file), or a different set, using whatever params I set including 5.1 LPCM (though I haven't tried that yet). And it can be played back as another input if necessary.
9. Certain mute buttons are set to be remotely triggered by a phone app so I can do channel swapping, soloing, etc on the fly...while I am on for example a Zoom meeting.
This all works without a hitch and with minimal latency.
Windows mixer can't do a fraction of that.
ScottLast edited by Cornucopia; 14th Sep 2021 at 00:22.
The OP didn't ask for all that. All he wants is to hear one audio input through his speakers.
I'm pretty sure the ability was in XP. It was certainly in Win7 and newer.
I don't have access to hardware running XP right now but on a virtual machine running XP there's a Mute button for each input in the mixer. Just un-tick that for your audio input -- I believe that will allow audio to go directly from the audio input to the speakers.Last edited by jagabo; 14th Sep 2021 at 13:45.
It is definitely possible and works the way jagabo described. I used this checkbox all the time back in the day with my PCI capture card. The input to unmute is called "Line in" and you may have to add it to the mixer if it isn't there already (don't worry, it is quite simple).
Thank you for the instructions; I'll give it a try in the next day or so hopefully and let you know what happens
You're probably talking about the "Listen" function in the sound control panel.
https://winaero.com/listen-to-microphone-with-playback-device-in-windows-10/
Yes, it could be used for this scenario, but it's primary purpose is for testing. Mainly because there isn't a lot of control over it other than the basic gain, so there is the good possibility of runaway audio feedback if you aren't careful.
Scott -
Here's the XP audio mixer from an old computer:
[Attachment 60739 - Click to enlarge]
The Rear Pink In (integrated Realtek audio device) was connected to an MP3 player's headphone output. The audio from the player was piped to the speakers. The Balance, Volume, and Mute controls worked as expected. Names may change depending on the audio device and Windows version. But the ability has been around for a very long time. I think even Win95 had it. -
Just hooked everything up and it worked perfectly; didn't have to adjust any settings. Just plugged into the audio in of the card, and that audio went out to the speakers; thanks!
Is there any soundcard that can capture at 384kHz?
By Videogamer555 in forum AudioReplies: 13Last Post: 6th Feb 2021, 04:55 -
Samsung Smart TV audio improvement to external speakers
By guatelize in forum AudioReplies: 15Last Post: 24th Apr 2019, 13:21 -
Will mono DVD audio play from both speakers?
By Bencuri in forum Authoring (DVD)Replies: 2Last Post: 23rd Oct 2018, 21:02 -
I need help on creating a video based on route map
By vbas28 in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2018, 11:23 -
Need help setting up z906 speakers to my soundcard
By sohaibrazzaq in forum AudioReplies: 6Last Post: 23rd Jul 2017, 11:51
