Trying to join two clips that are h.264 with no luck. As a test, I rendered them both using Virtualdub's x264 8-bit video encoder, and the LAME MP3 audio encoder, then tried to take those clips and join them together. Since they were both rendered using Vdub's own codec, I figured there wouldn't be an issue, but I'm getting an error when I try to stream copy:
And an error when I try full processing, smart render:Direct stream copy cannot be used with this video stream. You may want to select a different Input Driver.
Is this just a limitation of the x264 codec? Of course, my eventual use case would be to try and join two clips that weren't re-encoded by Vdub, but this experiment seems to suggest it isn't possible at all. Why is this?Cannot initialize smart rendering: The selected video codec is able to compress the source video, but cannot match the same compressed format.
I believe the smart rendering only works with AVI files. And you generally shouldn't use x264 in AVI. And you may need to force the AVI File reader when you open the video.
As in, .avi source and output files? Because .mp4 sources to .avi outputs didn't work, maybe I could try re-wrapping before my next attempt.
And you may need to force the AVI File reader when you open the video -
Some years ago I struggled to find a method that would losslessly join three or four MP4 / H.264 videos with no synchronization issue. The only one that worked flawlessly was ffmpeg with a temporary TS remuxing.
Code:ffmpeg -i "input1.mp4" -c copy -bsf h264_mp4toannexb "temp1.ts" ffmpeg -i "input2.mp4" -c copy -bsf h264_mp4toannexb "temp2.ts" ffmpeg -i "input3.mp4" -c copy -bsf h264_mp4toannexb "temp3.ts" ffmpeg -i "concat:temp1.ts|temp2.ts|temp3.ts" -c copy -absf aac_adtstoasc "output.mp4"
The source has to be AVI.
The AVI container was designed before codecs used out-of-order encoding/decoding. And Microsoft's VFW library (which many programs use to read/play AVI) doesn't handle out-of-order frames. So one has to use tricks to use such codecs in AVI -- usually called "Virtualdub Hack" or "Packed Bitstream".
At the Open Video File dialog use the Files Of Type pulldown to select Audio/Video Interleave (*.AVI, *.DIVX).
Some clips stutter after render, some don't - please help
By bbshopplf in forum EditingReplies: 10Last Post: 4th Jan 2019, 15:34 -
Is VP9 Available Yet in a Smart Render Editor?
By criggs in forum EditingReplies: 0Last Post: 15th Jun 2018, 20:07 -
Incompatible Video Files Joined Through Smart Render With VideoReDo
By criggs in forum EditingReplies: 0Last Post: 14th Jan 2017, 20:14 -
Smart Renderer 5 Won't Smart Render a Clip
By criggs in forum EditingReplies: 0Last Post: 5th Dec 2016, 10:41 -
Smart render. Lagarith > Vegas(edit) > Lagarith.
By ValentineStone in forum Video ConversionReplies: 11Last Post: 5th Oct 2016, 13:31
