try using yt-dlp directly, instead of switching to TVdownloader...
now last version of yt-dlp support francetv
Results 31 to 46 of 46
dosen't work I think its me i do something wrong!
I create a folder with yt-dlp, I rename to youtube-dl.
I have ffmpeg, ffplay and ffprobe in this folder.
i open the cmd and i write :
(just 2 min video for try)Code:youtube-dl -F https://www.france.tv/france-5/silence-ca-pousse/2838399-la-plante-de-la-semaine-solanum-amygdaloides.html
and i have always same message
Code:youtube-dl -F https://www.france.tv/france-5/silence-ca-pousse/2838399-la-plante-de-la-semaine-solanum-amygdaloides.html [FranceTVSite] 2838399-la-plante-de-la-semaine-solanum-amygdaloides: Downloading webpage [FranceTV] cf2de998-2a6d-11ec-9535-000d3a23d482: Downloading video JSON ERROR: [FranceTV] cf2de998-2a6d-11ec-9535-000d3a23d482: Unable to download JSON metadata: HTTP Error 404: Not Found (caused by <HTTPError 404: 'Not Found'>); please report this issue on https://github.com/yt-dlp/yt-dlp . Make sure you are using the latest version; type yt-dlp -U to update. Be sure to call yt-dlp with the --verbose flag and include its complete output.
I have no idea why you rename, you also don't need ffprobe or ffplay.
You also also don't need to use the actual link address, rather the manifest.mpd which can be found using developer tools -> Network
Code:ytdlp.exe --no-check-certificate "https://cloudingest.ftven.fr/a68228b6f3616/cf2de998-2a6d-11ec-9535-000d3a23d482_monde_TA.ism/ZXhwPTE2MzM5ODI0MjN+YWNsPSUyZmE2ODIyOGI2ZjM2MTYlMmZjZjJkZTk5OC0yYTZkLTExZWMtOTUzNS0wMDBkM2EyM2Q0ODJfbW9uZGVfVEEuaXNtKn5obWFjPWYzMGEwYzRiYzViZjgzN2FkZmU2MWUxOTQ5NDE0ZWQ0YzU5NGFhM2UyMWNmNWQ5MmY0MDU3ZjBiOTdmMzYwMzY=/manifest.mpd" -o frn.mp4
with de manifest.mpd work for the video but when downloading the audio i have this
[Attachment 61247 - Click to enlarge] -
its seems ok, but as it download fragment by fragment my download its very slow between [200kib/s to 1 2 mib/s] do you have a solution for this or not ?
btw i search on the web but i didn't find, if i want to download with the video all subtitle available in .str format what i need to add in the code ? -
For faster download, download aria2c and use --external-downloader aria2c as a parameter with ytdlp
https://github.com/aria2/aria2/releases/tag/release-1.36.0
For subtitles give me a link with subtitle so I can check, but you can try --all-subs with ytdlp -
After multiple try, I know how download file and subtitle, but ~10 minute for [400;600]mb file its too long.
I search how use aria2c but i don't find ? I want download with idm or jdownloader but i really don't know how do ?
PS : is possibile to convert the file in mkv directly or i need to do with ffmpeg after ?
Thanks for your reply -
with link suggestion by [ss]vegeta at post#38 download aria2c then put on same folder with yt-dlp
then run yt-dlp with command yt-dlp --allow-u --external-downloader aria2c ....mpd.url
IDM don't need to set nothing. simple play video, if IDM intercepts flush video you can download it, otherwise you can't do anything else -
please help me download video from this site https://www.iwanttfc.com/
(Watch the first 10 episodes for FREE). i have successfully downloaded from .mpd file but downloaded video is DRM encrypted i cant find key ID. Help me
Film: Marry me marry you (ep 10)
Link .mpdi used Widevine Decryptor but didn't find the keyHTML Code:https://absvod.akamaized.net/c/2/m/281d03a8-2b50-11ec-bbe7-bf5ea4d72538.ism/manifest.1920x1080.mpd
sometimes guesser not work properly on chrome. try with firefox.
ep10
Code:281d03a82b5011ecbbe7bf5ea4d72538:63cc0f7f17d1ba83b321b63b1ebd3d38
The guesser has been revoked with Wednesdays Chrome update. Still works on FF for now.
The "old workaround" works.Last edited by codehound; 22nd Oct 2021 at 03:39.
use old version or other chromium based (much better than the original chrome...) or FF.
Downloading subs saved as Annotations?
By kniwlotsip in forum Video Streaming DownloadingReplies: 4Last Post: 12th Sep 2021, 19:29 -
i need help downloading a movie
By cns00 in forum Video Streaming DownloadingReplies: 14Last Post: 14th Apr 2021, 13:15 -
Downloading a movie
By ABernard in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Jan 2019, 14:56 -
Help with downloading a NETU.TV movie
By luiisx7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Jun 2018, 06:03 -
Extracting and downloading one movie from youtube playlist
By David Banner in forum Video Streaming DownloadingReplies: 3Last Post: 27th May 2018, 16:35
