Hello,
any idea how to download this movie and SRT subtitles?
https://www.france.tv/series-et-fictions/telefilms/2743743-les-heritiers.html
youtube-dl returns a message:
"ERROR: Unable to download JSON metadata: HTTP Error 404: Not Found (caused by <HTTPError 404: 'Not Found'>)"
Movie is normally watchable with subtitles online.
TIA
EC
Results 1 to 30 of 46
I have figured out the URL to manifest.mpd file and streamlink does download the movie without problem but without including subtitles.
streamlink --mux-subtitles "https://cloudreplay.ftven.fr/aa85760c9b316/1036051817_france-domtom_TA.ism/ZXhwPTE2MzE1ODk0NDN+YWNsPSUyZmFhODU3NjBjOWIzMTYlMm YxMDM2MDUxODE3X2ZyYW5jZS1kb210b21fVEEuaXNtKn5obWFj PTA3NmY3YzgxMjFkODFhYWIwM2RhN2FjZTE2NGIyNTZlODdjM2 QzZWNjZjkxOGM2M2JiMWU3ZGViNmU2Y2ZhMGU=/manifest.mpd" 720p -o movie.ts
Any idea how to grab the subtitles alone, knowing MPD file?
TIA
EC -
manifest.mpd → textstream_fre=1000.webvtt
https://cloudreplay.ftven.fr/aa85760c9b316/1036051817_france-domtom_TA.ism/ZXhwPTE2MzE...NjBjOWIzMTYlMm YxMDM2MDUxODE3X2ZyYW5jZS1kb210b21fVEEuaXNtKn5obWFj PTA3NmY3YzgxMjFkODFhYWIwM2RhN2FjZTE2NGIyNTZlODdjM2 QzZWNjZjkxOGM2M2JiMWU3ZGViNmU2Y2ZhMGU=/textstream_fre=1000.webvtt -
Any idea why youtube-dl doesn't work anymore with france.tv ? It was working fine 3 days ago but now it exits with ERROR: Unable to download JSON metadata. Also ffmpeg stopped working for m3u8 videos from the same site, video download helper downloads the video but ffmpeg doesn't despite adding user agent referer username passwd ... it seems that a parameter used in the browser is missing.
EDIT: For those who want to help here's the login info (disposable temp email)
username: vesar24672@stvbz.com
passwd:Ben1c3pls.Last edited by jojo; 13th Sep 2021 at 20:38.
Youtube-dl is broken for france.tv and any software which is using youtube-dl (i.e. YoutubeVideoDownloader) is also broken. This issue was reported and someone has come up with a patch which seems to work https://github.com/ytdl-org/youtube-dl/issues/29956
For me the discussed patch against francetv.py hasn't changed anything for recent youtube-dl misbehavior.
However, streamlink on MPD manifest file does seem to work properly so there is a workaround, so I'd stick to it for a while (even though youtube-dl had seemed to work faster).
Thanks for your follow-up
EC -
I'm glad that once I shared my login credentials, which you requested, you were able to provide a "solution".
Edit: FYI the latest YT-DLP has merged youtube-dl v2021.06.06 which doesn't have the patch to work with france.tv so it's not able to download the json (same as youtube-dl or YoutubeVideoDownloader)Last edited by jojo; 14th Sep 2021 at 15:09.
@ecolek
Streamlink was/is very slow, that's why I was looking for another (faster) method ... haven't try yet the patch -
Care to provide the command/screenshot to download the initial video https://www.france.tv/series-et-fictions/telefilms/2743743-les-heritiers.html ?
--stream-segment-threads makes Streamlink downloads go a bit faster https://streamlink.github.io/cli.html#cmdoption-stream-segment-threads
Code:streamlink --stream-segment-threads 5 ".../manifest.mpd" best -o movie.mp4
discord=notaghost9997
@notaghost
Sorry but you lost me, I can also download the movie and subs and place it on mega, but I cannot do it with youtube-dl or any software which is using/based on youtube-dl (without the patch posted in my previous post). -
Getting the subs and mpd is not the issue.
I said that YoutubeVideoDownloader is not working since is using youtube-dl, and you get the same error. Here it is:
https://mega.nz/file/zc9GTYpR#CM3Mm2uBIDRLrQHMG90wY7CluP5sJO26kP891O5l4oY
You said that YoutubeVideoDownloader is working, well show us. -
TVDownloaderYou said that YoutubeVideoDownloader is working, well show us.
@karapuz Thank you.
For anyone interested, TVDownloader works, will download the movie, BUT:
- if in the Video Source URL (Youtube, Vimeo, DailyMotion, BBC, +900 more) field you put the URL for the movie as you are supposed to do then it will not work.
- if in the Video Source URL (Youtube, Vimeo, DailyMotion, BBC, +900 more) field you put the URL for manifest of the movie then it will work, the movie will be downloaded.
Edit: While the above (fix) was visible from karapuz post above (attachment) for whatever reason karapuz has edited the post and deleted the picture showing that in TVDownloader you have to put the URL to the manifest not the movie URL, ... so all credits should go to karapuzLast edited by jojo; 15th Sep 2021 at 12:55.
Thank you, it makes a huge difference.
Started both TVDownloader and Streamlink --stream-segment-threads 10, streamlink finished the download in less than 2 min, TVDownloader was still downloading ... 5.8% -
Once again problem appeared with getting the subtitles from another movie from France.tv..
On, nevermind, I used wget to download webvtt subtitles successfuly, please disregardLast edited by ecolek; 6th Oct 2021 at 11:35.
Someone have any idea with TVDownloader ? (video from france.tv)
Code:[FranceTV] 032c984d-c718-45dc-a56b-3f69a3ae47d0: Downloading video JSON ERROR: Unable to download JSON metadata: HTTP Error 404: Not Found (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
So I try this
thank you for the help I am a beginner so be simple whan your explain meCode:youtube-dl -U ERROR: can't find the current version. Please try again later.
FXMkD asked "Someone have any idea with TVDownloader ? (video from france.tv) "
Try this ....
There is a new version of yt-dlp and the changelog says
yt-dlp 2021.10.10
Changelog:
[francetv] Fix extractor by fstirlitz, sarnoud
Therefore :
1) Locate the directory where you have installed tvdownloader.
2) Download and copy yt-dlp.exe to the tvdownloader folder and rename to youtube-dl.exe -
First thanks for the reply.
I did what you told me to do and I have the same error.
Like you can see i have the new yt-dlp (look the new logo) and i rename
[Attachment 61240 - Click to enlarge]
[Attachment 61241 - Click to enlarge]
can you try on your side ?
Downloading subs saved as Annotations?
By kniwlotsip in forum Video Streaming DownloadingReplies: 4Last Post: 12th Sep 2021, 19:29 -
i need help downloading a movie
By cns00 in forum Video Streaming DownloadingReplies: 14Last Post: 14th Apr 2021, 13:15 -
Downloading a movie
By ABernard in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Jan 2019, 14:56 -
Help with downloading a NETU.TV movie
By luiisx7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Jun 2018, 06:03 -
Extracting and downloading one movie from youtube playlist
By David Banner in forum Video Streaming DownloadingReplies: 3Last Post: 27th May 2018, 16:35
