I need to crop and decrease bitrate of video in HDR. Do I need some special commands in ffmpeg, or just set filter for crop, and parameters for bitrate and 10bit pixels?
If your video is HDR10 (not HDR10+ or DolbyVision) you can crop&co you just need to make sure to properly set all the HDR related signaling to match the characteristics of your input.
see: https://codecalamity.com/encoding-uhd-4k-hdr10-videos-with-ffmpeg/
Note that when using HDR10+ the extracted dynamic meta data needs to be adjusted (no clue how) when you change resolution (resize/crop) or change the length of the video (trim, speed change,...).users currently on my ignore list: deadrats, Stears555, marcorocchini -
I just finished my first HDR in 29.5hrs
It looking very well, I cropped black lines (-82px) too, but probably I used to high bitrate 15mbps, it reduced size by 30GB, but still is very huge, 25GB. Thanks @Selur!
Any solution to transform HDR video to Youtube compatible HDR?
By Truthler in forum Video ConversionReplies: 2Last Post: 20th Jul 2021, 11:37 -
What is the best way to resize 4k HDR -> 1080p HDR? Are there gotchas?
By Msuix in forum Video ConversionReplies: 2Last Post: 1st Mar 2021, 02:58 -
MPC-BE HDR media in non HDR screens. Oversaturated picture.
By Zapa in forum Software PlayingReplies: 4Last Post: 29th Dec 2019, 11:31 -
4K x265 remove HDR but, keep HDR settings as a backup.
By Someonecool in forum Video ConversionReplies: 4Last Post: 22nd Oct 2018, 22:04 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 20:03
