I have downloaded files from a streaming site using internet download manager.They're only available as ts files.Each file is seperated into 2 files(video & audio).all the videos are ts and the majority of the audio is ts but some are aac.How do I merge bothe files into 1 file(mp4/avi/mkv)/
				Results 1 to 13 of 13
	You have to multiplex (mux, =combine) the single streams into a new container (ts, mp4, mkv, avi.. .).
 This can be done by g.e. clever Ffmpeg-GUI, mkvtoolnix, avidemux and other apps.
	If this streaming site is supported by the Video DownloadHelper add-on for your browser, you can possibly download it in one complete file when you use its Companion App (which is basically ffmpeg, used to multiplex the separately received streams).
	Hi.Tks for info.Have managed to use the mkv tool but wouldnt play on my smart tv.
 I converted them to avi using Wondershare and they now play.
 Another hurdle though.Video and audio out of sync.
 Any suggestions?
 Alan
	General
 Complete name : E:\Desktop\wwe\WWE Network - Armageddon 1999_audio.ts
 Format : ADTS
 Format/Info : Audio Data Transport Stream
 File size : 159 MiB
 Comment : google_3372851818781056814
 FileExtension_Invalid : aac aacp adts
 Audio
 Format : AAC LC
 Format/Info : Advanced Audio Codec Low Complexity
 Format version : Version 4
 Codec ID : 2
 Bit rate mode : Variable
 Channel(s) : 2 channels
 Channel layout : L R
 Sampling rate : 48.0 kHz
 Frame rate : 46.875 FPS (1024 SPF)
 Compression mode : Lossy
 Stream size : 159 MiB (100%)
 General
 Complete name : E:\Desktop\wwe\WWE Network - Armageddon 1999.ts
 Format : MPEG-TS
 File size : 1.85 GiB
 Duration : 2 h 49 min
 Overall bit rate : 1 563 kb/s
 Video
 Menu ID : 1 (0x1)
 Format : AVC
 Format profile : High@L4.1
 Format settings : CABAC / 4 Ref Frames
 Format settings, CABAC : Yes
 Format settings, Reference frames : 4 frames
 Codec ID : 27
 Bit rate : 1 512 kb/s
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Variable
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Stream size : 1.76 GiB (95%)
 Writing library : x264 core 148 r2643 5c65704
 Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=60 / keyint_min=31 / scenecut=0 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=1512 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1512 / vbv_bufsize=3024 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
	There is no need to recode this files.
 Use mkvtoolnix, start it, drag and drop both ts files into the upper window, select remux from the menu list and execute it.
 You have a new mkv file now with both video and audiostream incorporated.
 In case your TV cant play mkv you can remux this ts files into a mp4 container with clever Ffmpeg-GUI.Last edited by ProWo; 14th Sep 2021 at 07:53.
	Hi.
 Have managed to remux the 2 files into an avi which will play on my tv.
 But its out of sync.The video and audio files are different lengths.
 Can they be cropped and remuxed again?
	Play the avi with vlc player. In the tools menue, track synchronization, Audio track synchronization.
 Try different values here (start with +1 sec) with 1 sec steps for beginning, until A/V is in synch.
 If the value isnt to big, you can remux the video with the audiodelay you found.
	Then it's better to learn how to use ffmpeg directly -- I still use VDH sometimes to detect a video stream, but never bothered with the so-called "companion app" -- first of all, I hate the word "app" with a passion, then indeed it's only a fancy stupid name for ffmpeg doing the stuff under-the-hood, and it doesn't give you any control over what is actually being done, and last but not least these add-ons can break at any moment with no warning (such as what happened a few years back with the Firefox Quantum debacle, when suddenly, following a single fateful update, hundreds of add-ons stopped working, most of which died there and then as their developpers deemed that it was too much hassle to rewrite from scratch their little creation painstakingly made during their ever shrinking spare time). So, even as a beginner, it's best to stick as much as possible with time-proven tools and methods which allow you to know what you're actually doing and, if needed, to request help based on precise and verbose information.If this streaming site is supported by the Video DownloadHelper add-on for your browser, you can possibly download it in one complete file when you use its Companion App (which is basically ffmpeg, used to multiplex the separately received streams).
 Based on the MediaInfo report, this may be the cause :Have managed to use the mkv tool but wouldnt play on my smart tv.
 Standalone players don't like videos flagged as having a "variable framerate". Since most videos flagged as such have in fact a constant framerate, it could be fixed with no re-encoding. I had this issue once (an otherwise regular MKV file made from a standard DVD couldn't be played on my brother's BRD player), and I managed to solve it by applying the proper (constant) framerate using TSMuxer, then re-muxing the video with MKVToolNix (MKVToolNix alone could not fix this -- it may have changed in the mean time, it was around 2015).Code:Frame rate mode : Variable
  video & audio out of sync - Video DownloadHelper & vimeo videosBy sparkles in forum Video Streaming DownloadingReplies: 10Last Post: 5th Aug 2023, 12:32
  A newbie attempting to merge video & audio filesBy gillsimo in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2020, 15:33
  FFMpeg merging audio files truncates output to shortest audio fileBy Wayneos in forum Video ConversionReplies: 0Last Post: 3rd Jul 2019, 08:07
  ToolNix / Avidemux merging mp4, 2nd part grey video correct audioBy jfjfjf in forum EditingReplies: 5Last Post: 18th Nov 2017, 16:56
  Merging separate audio and video files into one (and keeping the shortest)By StaffHerb in forum Video ConversionReplies: 2Last Post: 8th Dec 2016, 15:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
