Hi there - just wanted to see if anyone had any experience with this - I'm still using TMPG Authoring Works 4, which i know is outdated but it works fine for what I'm doing and I've never upgraded.
All of a sudden, I cannot launch the Batch authoring tool. It worked fine for me on Thursday, and then Friday it did not work. No changes to my system took place, it didn't work and i have not been able to launch it since. When i try, it hangs up and then i go into task manager to see it is using 16% of my CPU capabilities.
Has anyone ever had that issue, and/or anyone have any recommendations? I suppose i could just uninstall and reinstall and see if that works?
Thanks for any help!
Is there a project file saved in the batch authoring where the video files have been removed?Might be looking for them and gets stalled not finding them.
Thanks for your help. I was kind of thinking about that. I got into the habit of not clearing/deleting the batch projects, but it has never been a problem. Is there any way I can clear them, i'm assuming there is some temp folder or some item somewhere that i could possibly delete?
thanks again! -
I solved it - it's under the documents folder- my batch saved projects file was 8 GB. I assume that was causing the problem. I deleted it and voila!
Thanks again for your help! -
Well my problem is that it can't accept more languages and sub tracks, and it can creates a sub menu on the main menu with settings for audio and subs
TMPGEnc Authoring Works 5 Menu Help
By hurricane1951 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Feb 2022, 14:28 -
applying a filter to a batch in tmpg mastering works 5
By devdev in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2019, 10:49 -
Problem with TMPGEnc Authoring works 6
By pablur in forum Authoring (Blu-ray)Replies: 3Last Post: 9th May 2019, 05:49 -
Incorrect aspect ratio after authoring in FMPGEnc Authoring Works 6
By ibzomie in forum Authoring (DVD)Replies: 2Last Post: 19th Dec 2018, 09:14 -
Promlem Burning BluRay with TMPG Authoring Works 5
By rward39571 in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Oct 2017, 09:28
