Hello,
I'm trying to remove the horizontal lines with Avisynth from a TV documentary that I have only found available on Youtube. I know, I know. I've read tons of forum posts here and already know how people feel about the crap quality of Youtube videos. However, the documentary has never been released on VHS or DVD, to my knowledge, so this is the only thing I have to work with.
Anyway, I have attached a clip that shows the lines that I want to see if they can be removed. It is most noticeable on the US Flag and the boys ringing the bells. Other than clipping out this bit of the video in AviDemux, I haven't done anything to it. Can anything be done in AviSynth, or is it something that I just have to live with?
The usual approach is: downscale horizontally until the lines are gone then upscale back to the original resolution.
Seeing that the video you downloaded 920x720 I would recommend to first look try a lower resolution version, with a bit of luck you might have a better change to get rid of these combing artifacts on a less processes lower resolution version of that video that way.
Otherwise you probably would have to reduce the horizontal resolution probably down to 240 (or lower) and then upscale from there.
-> I would recommend to try with a lower resolution version
Cu Selur
Ps.: got a link to the YouTube documentary?Last edited by Selur; 12th Sep 2021 at 12:21.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Sure. Here it is:
https://www.youtube.com/watch?v=jXbxoy4Mges -
My guess would be:
a. download the 320 version
b. treat it as if it was tff interlaced (= apply QTGMC or another deinterlacer)
c. resize to the resolution you want
may be someone else has a better solution.
You could also contact NBC whether the would/could provide you with a better version or point to where to get one.
(no clue whether the version over at peacocktv.com is better)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Ha! read the text under the youtube site and there are a link to the file that was uploaded to youtube!
http://www.mediafire.com/file/wk4i7hp3cd29pu5/911_Operation_Yellow_Ribbon_Gander_Newfo...dland.mp4/file
sadly that file already contained these combing artefacts, so I probably would still use the 320 version.users currently on my ignore list: deadrats, Stears555, marcorocchini
How to remove horizontal lines
By ziggy1971 in forum Video ConversionReplies: 17Last Post: 26th Jan 2021, 08:49 -
Horizontal Lines from VHS
By Pougan in forum Capturing and VCRReplies: 11Last Post: 25th Sep 2020, 01:16 -
VHS horizontal lines
By VHS_Hunter in forum RestorationReplies: 5Last Post: 27th Apr 2020, 00:45 -
Scrolling horizontal interference lines
By Chief Mouse in forum RestorationReplies: 5Last Post: 28th Jul 2018, 16:16 -
Help Removing horizontal/vertical film lines, scratches, patches etc.
By yukukuhi in forum RestorationReplies: 1Last Post: 16th Apr 2018, 12:04
