For years I have been using MKVMerge GUI v6.4.1 to mux my MKV files without problems. Recently I decided to try the latest version of MKVToolNix Gui v61.0.0. The problem with that is that it creates global tags, which prevent me from seeing the videofile’s dimensions in Windows explorer.
So how do I prevent MKVToolNix from creating global tags? I cannot even see the global tags and delete them in MKVToolNix, which I can in the old MKVMerge, but that is an unsatisfying solution. Much better to prevent them from being created if possible.
Open MKVToolNix
CTRL+P: addhere:Code:--disable-track-statistics-tags
[Attachment 60693 - Click to enlarge]
close MKVToolNix (important!!)
open it again and open a source file, then check ifis present in command line:Code:--disable-track-statistics-tags
[Attachment 60694 - Click to enlarge] -
Thanks, it worked. Now can you also tell med how to make MKVToolNix remove the sourcefile automatically after a succesfull muxing?
Help creating batch script for Header editor using mkvtoolnix.
By Jaco in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2021, 20:16 -
Is converting VSFilterMod tags to mainstream tags possible?
By zerxes96 in forum SubtitleReplies: 0Last Post: 29th Apr 2020, 20:39 -
Prevent PotPlayer from going asleep
By Anakunda in forum Software PlayingReplies: 0Last Post: 30th Apr 2019, 05:16 -
How to prevent old Hi8 tapes from stretching?
By Master Tape in forum MediaReplies: 0Last Post: 18th Aug 2018, 02:16 -
OTT adds 25bn to global video industry
By Lilbar in forum Latest Video NewsReplies: 0Last Post: 6th Oct 2016, 10:09
