When I download videos from social media sites I often find that they crash VLC Player for Windows. Is there a utility that will scan an entire MP4, look for obvious errors, and fix those errors, writing out a new file?
A simple remux often helps.
You can use clever Ffmpeg-GUI for that.
Load your mp4, click main, click multiplex, select mp4 as container, click multiplex. Done. -
Corrupted files happen to exist, but if this happens frequently this is not normal.
You should check the SMART status for the storage device where those files are stored. (Anyone using a computer should regularly check the SMART status for any storage device connected to it, but in such a situation I would be especially cautious, as it may be a first warning of a much more serious underlying issue with your own hardware.)
Also check the event viewer to see if there are specific warnings associated with VLC Media Player crashing.
Best fix for poorly deinterlaced or "filmised" PAL video?
By DragonQ in forum RestorationReplies: 3Last Post: 29th Jan 2021, 06:31 -
Forced scan type to "Progressive" after VirtualDub encoding
By GD314 in forum Video ConversionReplies: 5Last Post: 13th Mar 2020, 11:06 -
how to do: "-vf interlace=lowpass=0:scan=tff" using FFMBC.EXE?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 27th Nov 2019, 13:11 -
DVD "fake" 5.1 DTS is actually stereo... how to fix empty channels?
By Sapito in forum AudioReplies: 1Last Post: 3rd Jan 2019, 04:31 -
Fix: "The tray is being operated or a disc is being read" Sony BluRay USB
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th May 2017, 06:54
