  1. What is the best codec library currently available - and still maintained regularly - for Windows 8? I read about one named K-Lite. How does that compare to others?
    Is there any easy way to NOT have the codec library replace the default codecs under Windows? I would prefer to have the codec installer only install codecs for which Windows offers no support.
  2. For playback just use a player with built in codecs. For encoding install only the codecs you need/want. There's no reason to install codec packs.
  3. Originally Posted by jagabo View Post
    I want to see a preview of an image from the video in Windows File Explorer.
  4. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Icaros will show thumbnails for almost all video types...https://www.videohelp.com/software/Icaros
    A codec pack is a good way to hose the OS, and have to reinstall it.
