How to convert wav to flac in FLAC Encoder?
	Use clever Ffmpeg-GUI instead.
 Load yor wav, click main, click audio conversion, click continue, select flac as output, click convert. Done.
	Open a command-prompt window, type "flac --explain", press "ENTER". "Programmers are human-shaped machines that transform alcohol into bugs."
	dBPoweramp is a nice little GUI that converts one or multiple WAV files to FLAC fast and easy.
	Code:flac -f -F -5 -o "Path to output .flac file" "Path to input audio file" - -f, --force Force overwriting of output file
- -5, --compression-level-5          Synonymous with -l 8 -b 4096 -m -r 5
 -5 is the default setting
- -o ".." Set output file
-  -F, --decode-through-errors  By default flac stops decoding with an error
 and removes the partially decoded file if it
 encounters a bitstream error. With -F, errors
 are still printed but flac will continue
 decoding to completion. Note that errors may
 cause the decoded audio to be missing some
 samples or have silent sections.
 Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
  Ripping a DVD Audio disc into WAV or FLACBy efiste2 in forum AudioReplies: 2Last Post: 15th Nov 2020, 11:59
  ISO file to Flac or WAVBy efiste2 in forum AudioReplies: 1Last Post: 17th Nov 2019, 00:22
  MP3,WMA,DVD PCM but no WAV,OGG,FLAC,OPUS,AMR,etc.?By TechLord in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2018, 12:17
  Using MeGUI to convert AC3 and/or DTS to WAV or FLACBy CountChocula in forum AudioReplies: 4Last Post: 12th Aug 2017, 15:46
  24 Bits 5.1 FLAC Lower kHz than 16 Bits Stereo FLAC?By draig-llofrudd in forum AudioReplies: 5Last Post: 17th Dec 2016, 09:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
