    Mar 2014
    PALaland
    I am just recording an IPTV channel via VLC. I have right clicked the channel I am watching and then clicked Record in the menu. I can see the record button is active. But where is the VLC recording it? Couldn't find anything named 'Recording folder' or similar in the options. And I'm afraid to touch anything once the show is finished. What should I do to stop the recording properly and keep it? And where to find it afterwards?
    Mar 2008
    They're usually in
    c:\users\userid\videos
    Mar 2014
    PALaland
    Thanks. It wasn't there but rather in C:\Users\Username\Documents
    I've searched the C disk with the keyword "vlc" and found it that way.
    Still, how to change the default path in the VLC settings, I have no idea, can't find it.
    Aug 2006
    Maybe changing the default directory for snapshots, which is also C:\Users\Username\Documents, will also change the directory for recordings.
  5. Originally Posted by kodec View Post
    I used to do this many moons ago. Very hit 'n miss. Better to feed the individual channels m3u8 into OBS
    Check the stream's parameters and load the appropriate setting - resolution, bitrate, fps, etc
    OBS > Sources > VLC Video Source >
    I use OBS daily in my profession - hmu if you need any advice.
  6. Go to tools /preferences , Input / Codecs scroll down to Record Directory
