Howdy,
I have downloaded a single file that contains a subtitle from a movie but this is embedded in a .mp4 (.ismt) container, here is the media info:
Format : MPEG-4
Format profile : ISML
Codec ID : isml (isom/iso2/piff)
Codec ID/Hint : IIS Smooth Streaming file format
File size : 2.28 MiB
Duration : 1 h 28 min
Overall bit rate : 3 602 b/s
Encoded date : UTC 2020-05-01 20:35:25
Tagged date : UTC 2020-05-01 20:35:25
Text
Format : TTML
Format/Info : Timed Text Markup Language
Codec ID : dfxp
Compression mode : Lossless
Could someone help me to extract the subtitle (its the only subtitle in the file) and then convert it to .SRT subtitle or any other compatible. I also looked inside the embedded subtitle using note pad and it has all the lines.
If somone knows the answer or wants to help, I drop the file here: https://mega.nz/file/7E9gUAxT#-DEcFpLUqTkuQz9JzzwQLl0PPL0gGlIcE9p-x353CFE
Results 1 to 1 of 1
how to extract URL video embedded
By h.264 in forum DVB / IPTVReplies: 0Last Post: 8th Sep 2021, 08:01 -
Batch file to extract/convert all tx3g files in an .mp4 file
By olpdog in forum SubtitleReplies: 1Last Post: 23rd Aug 2020, 18:40 -
can i extract embedded subtitle from a downloaded video
By jraju in forum Video Streaming DownloadingReplies: 9Last Post: 16th May 2020, 19:46 -
embedded audio rate in mp4 video?
By jimjulian in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2019, 13:29 -
Retrieve subtitle file embedded in an MP4 video
By kasfig in forum SubtitleReplies: 5Last Post: 20th Feb 2019, 21:27
