Ok, i have a 756 mb movie, i was so mad that i couldnt fit this on 1 disc then some guy said that mpeg2's are special and that i could easily fit it on if I overburned.
I went into properties>expert features> and allowed it
then when i went into burn options before i burnt the file> on the top menus in the window, i went to the first 1 and instead of "try to fit to disk = 74 min" i clicked on "Users preferences" or whatever. then when i tried to burn it said insert a bigger cd...
then i set it 90 min and the overburn window popped up, yet it failed near the end of the burn
and my discs are 750 (74 min i think)... so what am i doing wrong? can someone tell me how to properly overburn this SVCD?
thanks, i've already got 2 coasters, dont wanna have 3
Results 1 to 12 of 12
Ok are you using an 80 minute cdr or is it's 74 minutes? you really should be using 80 minute disks
then look up your cdr an see if it supports overburning
it may not and trying to force nero to do it may damage the drive
my plexor does overburn but my previous cdr did not
I can get 850 or more on a 80 minute cdr in VCD/SVCD format - but it depends on your hardware and that you start out using 80 minute disksyour pal,
Stinky -
My bad... i totally listed wrong cd-r info
My cd's are 80 Min discs (700 mb).....
Please tell me how do you get so much data on it? i REALLY would like to know. -
I even read on this website that 800 mb will fit on a 80 min cd.... but it doesnt tell me exactly how to do this argh!, i want to know, and i really need to know by the end of today, thanks.
I will assume you are selecting ( Within Nero ) to make an SVCD
and not just a simple data-disc ?
8) -
CompUSA sells a 850 MB, 99 minute CD. Works perfect with nero. I guess that your file is just a bit too large. the 99 minute CD will do it for you. SKU 47669 17059. the cost is less than 10 for 16 cd and jewel case.
good luck -
i dont have those other discs...
yes, i select svcd within nero to do this...
what im asking is how i overburn to fit 760 or so on a 80 min cd (like the other guy said) can i do this or not?
it says i can do this on the site and t hat its possible to fit 800 mbo n a 80 min cd... please someone tell me how to do this, i know i can go out and buy the bigger min cd... but i have 80 mins, so i want to know if i can do this with an 80 min cd -
phhoth, i went to compusa today and they said they dont carry 90 or 99 min cd's.... i even asked a second person to make sure..... and they said no.... i am tryin to burn cvd's and of them came out to be a gig so i wanted to try cd-r or rw and see if my burner can do them...... also i have a usb phillips and was wondering if anyone know if they can make a software update for the 99 min burning or is it a hardware limitation??????
@Madoshi X: it should come down to 2 things 1) did you change the settings in Nero to allow overburning 2) does your hardware support overburning?
if your hardware does not then all this trying my break your cdr - seriouslyyour pal,
Stinky -
I had this same problem tonight. I was finally able to overburn, but when I go to play it in PowerDVD, it reports an invalid file format. I read the nfo that came with it (Dark Angel's Freak Nation) and burned it as an SVCD, but no go. Could this be because I se the disc size to 84 minutes to allow over-burning? Nothing will play the file, either from disc or the downloaded file.
Dai
p.s. - Should the file be an .mpg file in the MPEG2 fodler on the disc? -
Well, I got a ncie surprise. While the Dark Angel I burned tonight won't play off my DVD drive, using PowerDVD or other software, it did play in my standalone, which is what I wanted anyway.
Dai
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57 -
convert x not working properly
By paullyon in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2010, 09:41 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 11:58 -
DVDs not playing properly
By peter31 in forum Newbie / General discussionsReplies: 4Last Post: 27th Oct 2009, 08:24
