  1. I'm trying to save a clip using the AVC [Film] (8bit) set but it's not working. Every time I try saving it, I get an error saying "Write error occurred on file "<anonymous pipe>": The pipe has been ended." Under Configure External Encoders, Encoder Sets, it says Name: AVC [Film] (8bit), Video Encoder: V AVC [Film] (8bit), Audio Encoder: A AAC @~192K [Qaac], Multiplexer: M MP4 {A/V}. Under Configure External Encoders, Encoders, V AVC [Film] (8bit), Edit External Encoder Profile, it says under the Main tab,
    Type: Video encoder
    Program: C:\Users\Bruce\Desktop\Shortcuts\VirtualDub\Bin\FFMpeg\ffmpeg.exe
    Command arguments: -y -f rawvideo -s %(width)x%(height) -r %(fpsnum)/%(fpsden) -i - -f mp4 -c:v libx264 -crf 18 -preset Medium -tune Film "%(tempvideofile)"
    Output filename: %(outputname).Video.mp4
    Launch parameters: Interpret non-zero return code as error (checked), Redirect standard output to log (checked), Redirect standard error to log (checked), Delete output file before starting (not checked).
    It says under the Video tab,
    Pixel format: yuv420p : 8 bit YUV 4:2:0
    Under Configure External Encoders, Encoders, A AAC @~192K [Qaac], Edit External Encoder Profile, it says under the Main tab,
    Type: Audio encoder
    Program: C:\Users\Bruce\Desktop\Shortcuts\VirtualDub\Bin\Qaac\Qaac.exe
    Command arguments: --tvbr 91 -q 2 --threading -i -o "%(tempaudiofile)" -
    Output filename: %(outputname).Audio.mp4
    It says under the Audio tab,
    Input format: WAV file
    Compression: Bypass compression (checked)
    Can someone tell me what I've done wrong?
    Mar 2008
    I think the Virtualdub external decoder option was a bit of a can of worms, not many used it.
    Almost everybody switched to Virtualdub2 with all it's built in options
    Edit, Deja Vu, I responded with same answer as this, to you, in 2019
    https://forum.videohelp.com/threads/394015-Need-help-finding-external-encoders-for-VirtualDub2
  3. Originally Posted by davexnet View Post
    Oh yeah, of course, I remember that now, thanks.
