Atm. there is nothing to report since you didn't care to share example calls and outputs.
-> Why can't you report it in details to their bug tracker (https://trac.ffmpeg.org) ?
(assuming it's not related to https://trac.ffmpeg.org/ticket/8680)users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thank you for your reply. I have not written to the bug tracker because I am not registered and do not want to register.
If you want, you can easily check my statement with the following command:
The output of v4.4.(g.e):ffprobe -loglevel error -read_intervals 100%+20 -select_streams v:0 -show_entries frame=pkt_pts_time,pict_type "yourmovie.mkv"
[FRAME]
pkt_pts_time=115.949000
pict_type=P
[/FRAME]
The output of the latest full git (g.e.):
[FRAME]
pict_type=P
[/FRAME]
pkt_pts_time is missing. -
Looking at the history of ffprobe.c it shows:
Looking at the changes that were made, it looks like the option was renamed.Code:ffprobe: remove references to frame->pkt_pts The field was removed during the last major bump.
Instead of 'pkt_pts_time', only 'pts_time', needs to be used.
So no bug or similar, just you not being aware of changes.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
The Newest Version Of AmaRecTV
By dellsam34 in forum Capturing and VCRReplies: 17Last Post: 20th Apr 2024, 08:34 -
FFmpeg Windows builds at gyan.dev
By Gyan in forum Video ConversionReplies: 34Last Post: 11th Feb 2024, 11:46 -
KM Player latest version issue. How to solve the issue? Please help me
By jobsp90 in forum Software PlayingReplies: 0Last Post: 18th May 2020, 05:48 -
PORTABLE Minimal Git for Windows (version 2.22.0.1)
By El Heggunte in forum ComputerReplies: 0Last Post: 22nd Jul 2019, 20:24 -
newest version of Rtmp Explorer
By blanc in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2017, 08:10
