I have 2 h264 files I've run across while encoding my blu-rays they each are slightly different. Both files say they are encoded as interlaced. The first it looks like it's blended maybe? While the second I can't really tell what it is, it has both film and video content but the original was mastered on video according to the info I have. I'm not sure if it's my setup but when I load them into avisynth and just try to use QTGMC, yadif or even separate fields it never looks right. I did try ffindex, lsmash, dga and just loading it up into VirtualDub2 with deinterlace to see if that would even work.
Something simple like:
Doesn't seem to do anything at all, while a normal mpeg2 file off a DVD is fine. All I did was cut the files and remove the audio so these aren't processed in anyway.Code:LoadPlugin("LSMASHSource.dll") LWLibavVideoSource("File1.mkv") LoadPlugin("yadifmod2.dll") Yadifmod2(order=-1)
I copied them to my mega account if anyone wants to take a look.
https://mega.nz/folder/7XBVnCBK#mDL8m6zUE8p6hFKKrMVUCQ
File1.mkv is the one I need to mess with the most, while I would like to deinterlace it proper, eventually I would also like to make a copy with 23.976fps so I can insert a small part into a second file easily.
File1 is interlaced standard definition video that has been upscaled without consideration for the interlacing, pretty much ruining your chances of cleanly deinterlacing it. You certainly won't do it with any simple filter like Bob, Yadif, or QTGMC. This doesn't look too bad:
File2 has already been deinterlaced. You might clean it up a little with QTGMC(InputType=2).Code:LWLibavVideoSource("File1.mkv", cache=false, prefer_hw=2) BilinearResize(width,270) Sharpen(0.0, 0.7) nnedi3(dh=true) nnedi3(dh=true) -
@jagabo: Have you ever tried whether it makes a difference if you use something like DPID (http://avisynth.nl/index.php/DPID) instead of BilinearResize?
(on higher quality input; File1 doesn't really have much sharpness to it.)
C Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I haven't used DPID. I'll take a look at it. But the point of downscaling here is to eliminate detail (the combing artifacts), not preserve it.
Sure, but ideally you would keep as much as possible from the original details that don't container the combing artifacs.
But thanks, I just was wondering while you used bilinear and not something else.
Deinterlace PAL-DVD - VirtualDub AviSynth Lagarith
By KlemNT in forum EditingReplies: 95Last Post: 6th Jan 2022, 15:59 -
What AviSynth settings to use to best deinterlace this NTSC video?
By elektro in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2020, 11:02 -
Victor (JVC) HM-DHX1 Auto Deinterlace issue
By ArianK in forum Capturing and VCRReplies: 4Last Post: 9th Feb 2020, 15:52 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 21:05 -
Any way to deinterlace specific lines with AviSynth?
By premiumcapture in forum Capturing and VCRReplies: 14Last Post: 14th Sep 2016, 00:09
