Hello there!
I bought a new car that is unable to play lossless audio except from a CD (shouldn't have bought such a thing in the first place, but now it's too late). It does have USB and able to read CDs with files (.MP3 and .WMA). Problem is I want to listen .WAVs or any other lossless source. Is there any way I can "wrap" a .wav into mp3 or wma "container" to trick the device into reading the stream? I apologise for the stupidity of the question, I did my best to find a solution but failed. Berg
Results 1 to 10 of 10
What u mean. You should not have bought the CD player or the car
Surely there are more important things about a car than it's audio capabilities. And high bitrate mp3 will sound perfectly fine in such an enclosed space. -
The only other thing you can do is replace the player with one that plays wave and flac as well.
Try renaming the WAV file to MP3 or WMA. There's a small chance that may work. Especially if your WAV files are stereo, 16 bit, 44100Hz of 48000 Hz. It almost certainly won't work if they are more exotic like 5.1 channel, 24 bit, 96000 Hz.
I have found a solution. The car is Kia Sorento manufactured in 2018. I've used EAC for ages, but just recently noticed an option to encode .wav into .wma lossless. EAC will want to install a plugin from Micro$oft which is no longer available, I've used this one https://www.videohelp.com/software/Microsoft-Expression-Encoder
In this configuration EAC reads CD in it's normal way and compresses them into WMA Lossless which are perfectly playable from USB flash drive in my car. For the .wav files I have already read from CDs I've used WMAEncode64.exe having wrapped it in a simple batch file like this:
FOR %%I in (*.wav) DO WMAEncode64.exe --codec lossless "%%I" "%%~nI.wma"
The solution is described here: https://hydrogenaud.io/index.php/topic,90519.50.html -
While looking for the above solution I also noticed that, but failed to implement it practically. I earnestly tried, but WMP appears to be just beyond my comprehension. I also forgot to note that wma losslessness is clearly hearable in my car, despite an opinion that high bitrate mp3 will suffice for the car - it will not, to my ear.
I agree with you about WMP, one has to get into a certain frame of mind to "get it".
I tried it myself and had success.
Insert the CD and open WMP (if it doesn't open by itself)
Hit CTRL key + 1 to get to library/"now playing" view.
Confirm that the disk plays properly.
tool/options/rip music and confirm the rip settings.
Make your track selections and hit "Rip CD"
DVD to WAV/MP3
By Baldrick in forum AudioReplies: 38Last Post: 10th Oct 2020, 04:47 -
Item that plays on device does not play in VLC
By Keldin145014 in forum Newbie / General discussionsReplies: 9Last Post: 6th Oct 2020, 08:49 -
Device to play ISO files on TV without streaming?
By tjny in forum DVD & Blu-ray PlayersReplies: 22Last Post: 15th Sep 2019, 19:38 -
MP3,WMA,DVD PCM but no WAV,OGG,FLAC,OPUS,AMR,etc.?
By TechLord in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2018, 12:17 -
Choosing the media device that play MKV/TRUEHD
By liggy in forum Newbie / General discussionsReplies: 5Last Post: 30th Jun 2017, 04:41
