Hello all i read the forums and find some similar problem with vtt subtitles (segmetns), but in my case the steaming site use MPD not m3u8 playlits sorry my ignorance, in the past the same site (hbo max) use a single xml file and i can download without problem, now want to obtain some subtitles (only th subtitles) and cand find how, probable 300 segments for a tv episode, crazy to do individually, i have very poor knowledge about comand line
Sorry my english
I find this program N_m3u8DL-CLI_v2.9.7.exe but can grab the subtitles, can test with this mpd
Results 1 to 14 of 14
Thank you
but if i want to download other subs not only english? By the way the comand download all, video and audio only need subtitles
I find the command to download all subtitles but really not download all, i want to download forced subtitles, list the available subtitles and show me 2 vtt es-419 one is the forced, but with yt-dlp or youtube-dl only download the complete subtitle
need the forced
I tried with ffmpeg running this code
After a lot of warnings and errors, I got a list of all streams including subtitlesCode:ffmpeg -i "https://cmaf.lln.latam.hbomaxcdn.com/videos/GYPGKMQjoDkVLBQEAAAAo/1/1b5ad5/1_single_J8sExA_1080hi.mpd"
[Attachment 60638 - Click to enlarge]
Then I executed this code
But got this errorCode:ffmpeg -i "https://cmaf.lln.latam.hbomaxcdn.com/videos/GYPGKMQjoDkVLBQEAAAAo/1/1b5ad5/1_single_J8sExA_1080hi.mpd" -map 0:32 sub.vtt
I'm not sure why it happened, but maybe it's because of the drm.HTML Code:Stream mapping: Stream #0:32 -> #0:0 (webvtt (native) -> webvtt (native)) Press [q] to stop, [?] for help [dash @ 000000f4cd7bef40] No longer receiving stream_index 0 [dash @ 000000f4cd7bef40] No longer receiving stream_index 1 [dash @ 000000f4cd7bef40] No longer receiving stream_index 2 [dash @ 000000f4cd7bef40] No longer receiving stream_index 3 [dash @ 000000f4cd7bef40] No longer receiving stream_index 4 [dash @ 000000f4cd7bef40] No longer receiving stream_index 5 [dash @ 000000f4cd7bef40] No longer receiving stream_index 6 [dash @ 000000f4cd7bef40] No longer receiving stream_index 7 [dash @ 000000f4cd7bef40] No longer receiving stream_index 8 [dash @ 000000f4cd7bef40] No longer receiving stream_index 9 [dash @ 000000f4cd7bef40] No longer receiving stream_index 10 [dash @ 000000f4cd7bef40] No longer receiving stream_index 11 [dash @ 000000f4cd7bef40] No longer receiving stream_index 12 [dash @ 000000f4cd7bef40] No longer receiving stream_index 13 [dash @ 000000f4cd7bef40] No longer receiving stream_index 14 [dash @ 000000f4cd7bef40] No longer receiving stream_index 15 [dash @ 000000f4cd7bef40] No longer receiving stream_index 16 [dash @ 000000f4cd7bef40] No longer receiving stream_index 17 [dash @ 000000f4cd7bef40] No longer receiving stream_index 18 [dash @ 000000f4cd7bef40] No longer receiving stream_index 19 [dash @ 000000f4cd7bef40] No longer receiving stream_index 20 [dash @ 000000f4cd7bef40] No longer receiving stream_index 21 [dash @ 000000f4cd7bef40] No longer receiving stream_index 22 [dash @ 000000f4cd7bef40] No longer receiving stream_index 23 [dash @ 000000f4cd7bef40] No longer receiving stream_index 24 [dash @ 000000f4cd7bef40] No longer receiving stream_index 25 [dash @ 000000f4cd7bef40] No longer receiving stream_index 26 [dash @ 000000f4cd7bef40] No longer receiving stream_index 27 [dash @ 000000f4cd7bef40] No longer receiving stream_index 28 [dash @ 000000f4cd7bef40] No longer receiving stream_index 29 [dash @ 000000f4cd7bef40] No longer receiving stream_index 30 [dash @ 000000f4cd7bef40] No longer receiving stream_index 31 [dash @ 000000f4cd7bef40] No longer receiving stream_index 33 [dash @ 000000f4cd7bef40] No longer receiving stream_index 34 size= 0kB time=00:00:00.00 bitrate=N/A speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used)
Thanks!! I tried using this code to download subtitles from a streaming site and it successfully combined all segments into one subtitle file, but the timestamps are wrong tho... I know that the segments are 8 seconds each. Is there a way to modify the code so that the subtitles can have correct timestamps?
The mpd link: https://ewcdn108.nowe.com/session/15-5-3baa-0001000156347512676398/Content/DASH_VOS3/V...2/manifest.mpd
need help to download m3u8(.vtt) - .HAR file available
By Hamwi1985 in forum Video Streaming DownloadingReplies: 4Last Post: 7th Jul 2021, 07:31 -
Downloading WebVTT/VTT Subtitles from M3u8 web sites?
By vega69-ux in forum Video Streaming DownloadingReplies: 6Last Post: 29th Sep 2020, 13:45 -
what is the easy way to convert vtt to srt?
By sommers in forum SubtitleReplies: 3Last Post: 28th Jul 2020, 23:15 -
Multiple vtt's to single srt
By qaqaqaq in forum SubtitleReplies: 3Last Post: 15th Sep 2019, 01:50 -
Help with m3u8 vtt link
By perwann in forum Video Streaming DownloadingReplies: 8Last Post: 19th Nov 2018, 08:37
i want help to learn how download and need forced spanish subtitles, not pt-br
