Hi,
I have a Samsung ln40e550f7f TV that I am trying to connect to an audio receiver. However, not able to find any kind of audio output port. There are a couple of HDMI ports but both say HDMI In. Does this model even have an audio output option?
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
according to the manual - https://www.manualslib.com/manual/267927/Samsung-Ln46e550f6f.html?page=8#manual
there's audio connections in the back of the tv. -
If you are connecting the tv sound to the receiver it has to go through the optical audio connector from the tv out to the receiver optical in,it doesn't work with the hdmi that way.
It looks like there are no audio outputs on the TV. You'll need to put an AV Receiver between the HDMI source and the TV. Or open up the TV, disconnect the speakers and run the outputs to a decent pair of external speakers. I've done that on several TVs.
If you are running a separate device such as a cable box or game system you can run the cable box/game system through the receiver hdmi in and run the hdmi out to your tv,you will get sound this way and it's better quality.
Can't find suitable output format for X265
By smike in forum EditingReplies: 5Last Post: 30th Nov 2020, 07:18 -
How to find the name of the audio devices on windows 10 with FFmpeg?
By Valit in forum Newbie / General discussionsReplies: 0Last Post: 7th Apr 2020, 07:34 -
FFMpeg merging audio files truncates output to shortest audio file
By Wayneos in forum Video ConversionReplies: 0Last Post: 3rd Jul 2019, 07:07 -
XMedia Recode can't find audio track
By ZeroEmpire in forum Newbie / General discussionsReplies: 0Last Post: 27th Jan 2018, 12:22 -
Find Audio Delay
By sirbubby in forum AudioReplies: 8Last Post: 12th Jan 2017, 08:08
