I can't find any application to make it possible to download from the flemish VTMgo platform. I think this streams are DRM protected.
I want to download 4 episodes of a serie; via screen recorder should this be possible.
Which screen recorder should I use? Every screen recorder I used so far gives black picture when I start to playback the video...
thanks for the advice!
Gert
Results 1 to 13 of 13
Provide links and user/password via private message and we might be able to get you the show the proper way, not the screen recorder way.
By the way, try disabling hardware acceleration in Chrome, it might fix your black screen "problem".
Or try another browser like Firefox. -
It seems like I've solved my problem. Playing back the videofiles using Firefox instead of Safari was the clue. No more black pictures.
I haven't found a solution yet to download directly from VTMgo, but playing back and recording the file is a good solution for the episodes I've missed.
Thanks for the clue called OBS! -
VTMgo does seem to have some problems decrypting the files from the MPD file. I tried this one:
https://dcs-vod.apis.anvato.net/vod/p/manifest.mpd?encp=H2j4EXbClh_8FqhQJd6KCQ:7g8KeYp...6&t=1632230654
But after decrypting the audio/video mp4s with the 5 provided keys, the endresult is the last 15-20 minutes of 35. It's like there are some keys missing. -
The videos are split by parts, as can be seen by -0 -1...
[Attachment 60841 - Click to enlarge]
So you need to download the parts and decrypt them with different keys (maybe, analyze the mpd and KIDs) then merge them. -
So I understand there's another way to get video downloaded from VTM Go instead of capturing the screen (which 1. doesn’t work with my laptop (I've tried a few times with OBS but crashes) and 2. The quality of such a screen recording isn’t the same as when you just could download the entire file in a few minutes).
But it all seems very complicated... Is there anyone here who could and would help me (step by step) to take that procedure? I understood that, first of all, I need to install four different programmes? Many thanks in advance! -
What's the best Screen Recorder I can get for Windows 10 (w/ system audio)?
By massafera in forum Video Streaming DownloadingReplies: 4Last Post: 7th May 2022, 02:21 -
Simple Screen Recorder for Linux
By giacoesposito in forum RestorationReplies: 6Last Post: 14th Mar 2021, 03:02 -
Best screen recorder for low spec laptop?
By db09 in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2020, 08:04 -
what screen recorder alternative to bandicam?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2020, 06:33 -
download off of dailymotion title screen letters are backward
By RBCC in forum EditingReplies: 2Last Post: 16th Dec 2017, 21:12
