  1. Hello,
    I try to decrypt a video but after using ./mp4decrypt the video is always encrypted
    ./mp4decrypt --show-progress --key 1:f32bf84de25df70ec2d5d2764be0b5e1:912891f41b45d04 44311652529acd734 --key 2:c2abc4e30e5573c40a622b6006d74908:b2b127b30c7d855 bed798f098866272e --show-progress /root/Téléchargements/web_drm_720p_dash_v2.mp4 output.mp4
    https://mega.nz/folder/pskHDCJA#UUjOH6v3WnFdh1FCvjCdNA
    Could you help me ?
    Thanks in advance.
    Cédric.
  2. What's the source of this?
    It seems to me that the audio was not encrypted, the video was encrypted and you somehow managed to mux them.
    Now you can't decrypt, I think.
    You need to have the video stream alone, encrypted, then decrypt it, then mux with audio.
  3. psaframe
    Mar 2021
    Algeria
    my be your decryption key is wrong?
    Check this out 912891f41b45d04 44311652529acd734
    space btw "4 4"
  4. Originally Posted by naim2007 View Post
    space btw "4 4"
    His code is weird. Decryption keys might be wrong but he has another problem, as I mentioned.
    The space is added by the forum, we talked about this in another thread.
  5. Originally Posted by cedric8528 View Post
    Hello,
    Could you help me ?
    Thanks in advance.
    Cédric.
    your file and a TS mp4decrypt and not compatible for TS
  6. Each of the keys have 3 parts: 1 (or 2), an ID, and the key. One too many. If the IDs are correct, delete the "1:" and "2:".
    Also you specified the "--show-progress" twice.
  7. The file is saved 'FFmpeg'. You do not decrypt it.
