  1. I'm trying to get the vtt subs for this program. I can get them manually via the console but is there a simple curl or wget command that will automatically capture them at the same time as the video files. They're listed in the manifest but youtube-dl doesn't get them when it gets the vids.
    https://www.tg4.ie/ga/player/catagoir/faisneis/seinn/?pid=5663219410001&title=Jump%20B...s&pcode=417097
    Any help would be greatly appreciated.
    Feb 2006
    use the firefox add-on called "the stream detector", set it to youtube-dl, play the video with subtitles,
    you will see the vtt subtitle file, copy it and use youtube-dl to download the subtitles.
  3. Thanks for the help but I was wondering if there is a curl command which can read through the manifest, locate the subs url and download them automatically.
    Does anyone know if this is possible?
