i know that the video would be better captured via firewire but the video on the tape is not really important and i really don't want to buy a firewire card and cable for it to be only used one time
what software would i need to be able to capture via usb?
also would windows 10 even be able to work with this camera
does windows 10 recognize the camera ?? if not
try the windows compatibility mode option - https://www.sevenforums.com/drivers/44205-panasonic-nv-gs75-camcorder-driver.htmlLast edited by october262; 1st Sep 2021 at 22:32.
The USB port on DV camcorders were usually for transferring still images and low-res versions of the DV video -- poorly deinterlaced 320x240 MJPEG video. If not, a Firewire card is cheaper than a decent analog USB video capture device. Getting either to work with Win10 can be a hassle.
Some Panasonic models did have the ability to transfer DV over USB, the above model is one of them, So no capture device needed just a USB cable. But wether the original USB2DV driver will work under Win 10 or not, that remains to be seen.
Windows 10 update has rendered USB 2861 Capture Device unstable
By makeshift in forum Capturing and VCRReplies: 3Last Post: 3rd May 2023, 10:52 -
Tevion USB capture card not recognized (shows USB 2861 Video)
By retractOffer in forum Capturing and VCRReplies: 3Last Post: 4th Mar 2023, 12:38 -
Panasonic PV-GS120 Looking for USB driver and capture software
By mikeharakal in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2021, 17:00 -
Panasonic FS500B - USB HDD To PC
By CJB in forum Capturing and VCRReplies: 1Last Post: 11th May 2021, 11:55 -
Panasonic TV not displaying subtitles from USB stick
By millsy5 in forum SubtitleReplies: 34Last Post: 13th Feb 2021, 16:34
