My problem is that I have 2 subtitle tracks, one is named "English signs and songs" and another is called "English full". I also have English and Japanese audio tracks (dual audio). I need to downscale the videos to psp resolution and im using handbrake for that. for my subtitle selection behaviour ive mad eit as first matching selected language;english;burn-in behaviour=first track. however even after using that it selects signs and songs as the burned in subtitle. however signs and songs are a blank subtitle. since it is automatically selected its very hard to change the subtitle for each of the 200+ videos im converting. so is their a way to automatically choose english full subtitle or perhaps remove signs and songs subtitles completely? im aware i can do indivudally in handbrake itself but it will consume too much time.
Results 1 to 11 of 11
mkvtoolnix gui
Add source file, uncheckmark the streams that you do not want, press start multiplexing -
ive already tried this method but it seems to disable japanese audio
ive already tried the last method that seemed to have worked for the op of the thread linked
https://forum.videohelp.com/threads/393447-Batch-remove-subtitles-from-mkv-files
but japanese audio is deselected in all videos and ill have to reenable each fo them individually which makes no difference from doing using handbrake
it would be easier to change it if there was a shortcut for switching videos like how one switches tabs in chrome (ctrl+tab;ctrl+shift+tab)
does such a shortcut exist either for handbrake or mkvtoolnix?
if not what other solutions are available
also thank you for your quick reply i dint expect a 15 year old forum to still be active! -
Did you experiment with checking the default option and/or the forced flag option in mkvtoolnix's General Options pane for the English subs that you want to keep to see what happens?
I have only used mkvtoonix a few times and not recently but I don't think mkvtoolnix's GUI can batch process files. However, if you know how to write scripts, mkvmerge, which is doing all the work in the background, is fully scriptable via its command line.
I think this forum dates from at least the year 2000 when it was called VCDHelp but I didn't find it until 2005.Last edited by usually_quiet; 1st Sep 2021 at 12:21.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
[Attachment 60556 - Click to enlarge]
that is my general options pane but i dont see any of the mentioned options -
i want to expand on my question- what i actually want is to completely delete the "english-signs and songs" subtitle without reencoding the whole video.i only want to remove the subtitle track.
Use clever FFmpeg-GUI.
Load your mkv, click main, click multiplex, unselect the streams you want remove, click target file, accept (or modify) the proposed file name, click multiplex. Done.Last edited by ProWo; 4th Sep 2021 at 05:09.
dude i have 100s of files of which i dont want to select streams individually as that would take a lot of time and is also the reason for me asking this question in the first place. i want it to automtically select the streams i want ONLY.
i have already found a solution using ffmpeg cli
https://superuser.com/questions/1672698/removal-of-select-subtitle-tracks-and-audio-tr...672767#1672767
thx for trying anyways
Removing EIA-608 subtitles from mkv, FFMPEG filter_units unit docs
By nicholasserra in forum Video ConversionReplies: 10Last Post: 1st Feb 2022, 14:45 -
Muxing MKV with different audio tracks
By Chris Newbold in forum Blu-ray RippingReplies: 3Last Post: 28th Aug 2021, 06:21 -
Viewing & removing non-English audio tracks from 1000's of assorted MKV's
By kjac in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2018, 00:05 -
Compress MKV files with multiple audio tracks and subtitles
By tonyaldr in forum Video ConversionReplies: 1Last Post: 29th Jan 2018, 07:57
