So lately I have been looking at different ways to get web-dl. When looking around I found the widevine-guesser. I like it but it seems like a lot of setup on the system. Instead I have been just using ytdlp with cookies being passed to it then using ffmpeg for x265 compression. All being done within a bat file that I can load a list of links and have it run over night. Is the way I am doing it over night not the proper way?
What you are saying is confusing.
Widevine gusser is for getting keys. It's definitely not "a lot of setup on the system" since it's a "simple" extension for your browser.
If you are using only ytdlp and ffmpeg to get anything, it means the content is not encrypted.
You can't use ytdlp/ffmpeg INSTEAD of gusser, lol.
Anyway, whatever you are doing, if it's working, keep doing it. -
Because you can pass cookies to ytdlp you can get the file not encrypted on the system.
Code:%SN is given name %1 is link loaded from text file %2 is name of file loaded from text file
Code:yt-dlp --external-downloader aria2c --external-downloader-args "-x 16 -s 16 -k 3M" --cookies "%USERPROFILE%\Downloads\paramount\paramountplus.com_cookies.txt" -o "%USERPROFILE%\downloads\temp\%SN% %2.mp4" -f ("bestvideo[height<=720]+bestaudio/best[height<=720]") %1 title "%SN% %2"So what this does is just uses a batch file with a text file already loaded with links and names so it can download, compress and then I have more that runs filebot and transfer to the correct folders.Code:ffmpeg -i "%USERPROFILE%\downloads\temp\%SN% %2.mp4" -preset slow -pix_fmt yuv420p10le -c:v libx265 -x265-params profile=main10 -c:a copy -metadata:s:a:0 language=eng -c:s copy "%USERPROFILE%\downloads\temp\transfer\%SN% %2.mkv"
So not really any needed software other than YTDLP, FFMPEG and if a person chooses Filebot. All of this runs within CMD and batch files take care of everything.
What I was wondering is Widevine Guesser seems like you would have to grab a key file for every file you download. Instead this is just a list of a series that it can grab everything at once and run over night.
Is there anything that would make the web-dl a better copy from guesser vs ytdlp/ffmpeg?
I like the ability to use batch so I don't have to monitor. -
who knows how to download from paramount plus videos https://www.paramountplus.com/shows/video/uGPZXBptawT7eFjyWmXLuInXkSv9iN32/
All 4 Changes Braking MPD download
By HurMummer in forum Video Streaming DownloadingReplies: 8Last Post: 21st Mar 2022, 09:03 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 21:28 -
How to download this MPD?
By jdanielw in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2021, 04:55 -
Download this mpd... help
By leoglez29 in forum Video Streaming DownloadingReplies: 4Last Post: 17th Jul 2020, 22:25 -
how to download MPD
By gonto333 in forum Video Streaming DownloadingReplies: 1Last Post: 29th Jun 2020, 19:58
