Hi, dear Experts!
On my notebook HP ProBook 6560b, Intel corei5, Intel HD Graphics 3000, I have two hard disks installed: a main ST-harddisk with Windows 10 Prox64 and a WDC-harddisk with Windows 8.1 Prox64.
Both systems and necessary additional software are up-to-date.
On both hard disks is the newest version of OBS Studio installed.
When I'm making a screen capture therewith, it functions on Windows 8.1 excellent, without any error.
But the sound in the stored avi-file on Windows 10 is consequently delayed.
At the about one hour long file, this delay is about 2 seconds on the end.
What is causing this problem and how could be possible to its eliminating?
Many thanks in advance for your ideas! Regards-Glen
Screen capture is prone to even more issues than video capture.
So many factors. Your system memory. The size of the screen (full or windowed). The speed of the HDD. Other program(s) running in the background. There are probably others which I can not think of right now
You could, possibly, eliminate to HDD by nominating the WDC for the Win10 capture. That in itself could solve issues where the OS is trying to write to the main drive at the same time.
Task Manager should tell you if other programs, which may not be required at that specific point, are running and could be closed down. E.G. For screen-capture do you require internet access (unless you are recording an online game) and that itself could well be writing to the drive. -
@D883
Sorry, I've made a mistake. Windows 10 is installed on the WDC hard disk and Windows 8.1 on the ST hard disk. When I stream something from the Internet, the conditions are the same on both systems. And then, I take the screen recording with the same browser, namely the same Portable Opera (up-to-date), always working on the system drive in the “Portable Tools” directory. So, all of the parameters mentioned by you can't affect the sound delay on OBS Studio at Windows 10. -
Well the only thing that changes from my reply is the nominated HDD. Use the Win8.1 (ST).
I am not suggesting that is the solution since there is no easy one.
Others my have different ideas. -
Hi.
This is an interesting read.
https://streamershaven.blog/stream-tutorials/fix-audio-sync-issues-in-obs/
Cheers.
How to capture anything with Obs Studio
By Baldrick in forum User guidesReplies: 1Last Post: 8th Sep 2021, 02:10 -
OBS studio stand alone?
By mol3000 in forum Capturing and VCRReplies: 3Last Post: 14th Dec 2020, 09:51 -
Hauppuage PVR2, OBS Studio, no sound?
By FussyBob in forum Capturing and VCRReplies: 24Last Post: 7th Sep 2020, 13:32 -
Question how to screen capture just part of window with OBS-Studio
By jimdagys in forum Video Streaming DownloadingReplies: 4Last Post: 17th Apr 2019, 22:27 -
How to record ANYTHING on your screen using the free OBS Studio!
By Baldrick in forum User guidesReplies: 0Last Post: 7th Dec 2017, 05:45
