Hi,
I want to do the following
- Take a 4K UHD .mkv
- keep the video tack as is
- keep all audio tracks as is
- add a new track , converting the DTS track (or DTS-HD) to AC-3
- keep the subtitle tracks as is
- output to an .mkv again
I used the Popcorn AudioConverter since it basically has a 1 button option , but I can't get it to work anymore.
The forum seems to be riddled with solutions that no longer work.
Could someone advise on a tool that
- is maintained
- does the job
and share the correct settings ?
Thx,
D.
Results 1 to 9 of 9
Use clever FFmpeg-GUI.
Load your file, main, convert audio stream, select your DTS stream, continue, encode to AC3, set the bitrate you like, leave all the other settings as they are, click on convert.
If done, click on multiplex, your new created ac3 file is already loaded, click Add Stream, select your original file again, leave all streams selected, click target file, accept (or change) the proposed filename, click on multiplex, done. -
Altho' no longer developed Popcorn MKV Audio converter does the job in situ. https://www.videohelp.com/software/PopCorn-MKV-AudioConverter Probably many other programs available to do it as well.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 7 Ultimate, QNAP NAS TS851 -
AviDemux or MKVToolNix in combination with Audacity as johns0 said.
The advantage of Popcorn MKV Audio converter is it does it in situ, ie one process. But the program does need a few helper programs installed, easily downloaded or from the authors site.
Any sound and mostly dts & dts-hd to ac3
By fits79 in forum AudioReplies: 35Last Post: 19th Mar 2022, 09:58 -
Batch Remux Multiple files Swapping video keeping rest of tracks
By xonathan in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2020, 13:10 -
Are there any pros in keeping a DTS audio track if a DTS-HD is available?
By alexd15 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Feb 2019, 05:22 -
Adding Subtitle tracks to existing DVD and BD ISOs
By solkap in forum Newbie / General discussionsReplies: 11Last Post: 7th Dec 2018, 21:54 -
Adding tracks to existing MKV file with MKVMerge
By pstnn in forum Video ConversionReplies: 4Last Post: 27th Aug 2017, 16:55
