Results 1 to 17 of 17
  1. I have a low quality mono mp3 voice 24 kHz, 48 kbps CBR, 32 bit float that I use as input for farther audio editing: first convert to pcm_f64le than upsample to 48 kHz, EQ, mixing with other pcm_f64le inputs. There is no noise there.
    Is there anything I can do to make it better? I mean add dithering, audio super resolution or anything else?
    Mar 2008
    Post a sample here to the thread
  3. Originally Posted by davexnet View Post
    See the attachment.
    Mar 2008
    I heard a little sibilance, what "improvement" do you think it needs?
  5. Ideally, apply a voice super resolution neural net that upsamples it to 48 kHz. Maybe add some dithering, I'm not sure. Reducing that little sibilance can only make it worse.
    Mar 2008
    Do you have any software in mind that does this? I've never heard of any software that has 'super resolution neural net" for
    something as basic as increasing the sample rate. Usually the dither is done when the bit depth is downsized,
    for reducing the sample rate, an anti-alias filter is usually applied
    I have an old copy of Sound Forge, I haven't tried it, but I wouldn't expect the up-sample to be detrimental to the sound .
    canada
    The voice sounds good enough for me,any adjustments wouldn't give it any difference in quality.
  8. Originally Posted by davexnet View Post
    https://paperswithcode.com/task/audio-super-resolution
    You're probably right.
    Mar 2008
    I don't think there is any working software available yet, might have
    been interesting to play around with.
    Izotope RX are using neural networks in some of their modules,
    such as music rebalancing
  10. Originally Posted by davexnet View Post
    Izotope RX
    Thank you, that's what I need. Their spectral recovery does exactly what I wrote above.
    It turned out to be quite a powerful program. Do you know if they have a tool for removing that "little sibilance"?
    Mar 2011
    Nova Scotia, Canada
    If the voiccve was recorded with a cheap mic, which is almost always the case, no software is going to make it sound like an audiophile recording.
    Mar 2008
    Originally Posted by qo4on View Post
    Izotope RX
    Their de-ess module
  13. I used ffmpeg for upsample it to 48 kHz like `aresample=48000:resampler=soxrrecision=33`.
    But Izotope has a curve instead. Do you know what settings should I use in this case?
    Mar 2008
    Izotope know what they're doing but I'd like an explanation on that also.
    My understanding was that the anti-aliasing filter was only required when
    when the sample rate was lowered, yet the filter in rx doesn't make it clear
  15. That's what I think too, but I'm not sure. I can't imagine any reason why I should cut off some of the upper frequencies when upsampling. Do you know anything about Pre-ringing?
    Mar 2008
    Not really, I'm reaching my limit on this stuff. There are others in the forum who may respond,
    might have to be patient, or start a new thread with a more relevant title
