Results 1 to 10 of 10
    Apr 2010
    London
    Hi Guys
    a few quick questions please ......
    Ok so I found my old Sony HI Camcorder with a few HI8 Tapes, my aim is to digitally capture those cards using my High End digital Capture Card AJA Kona
    Sadly the tape in the camcorder had to me spliced and repaired about 25 times as it kept on breaking, most people after repairing the tape twice would have thrown it away, but no the memories on the tape were special so a gave up a whole evening splicing and repairing and unwinding the whole tape through and through
    With analogue capture of its always a fine balance between RAW/Compressed & Hard drive space.
    The capture setting I have Chosen with AJA Kona is not RAW but Apple Pro Res HQ... Is this acceptable quality for what I trying to do archive old HI8 Tapes ?
    Video
    Format : ProRes
    Format version : Version 0
    Format profile : 422 HQ
    Codec ID : apch
    Duration : 7 min 20 s
    Bit rate mode : Constant
    Bit rate : 68.8 Mb/s
    Width : 720 pixels
    Clean aperture width : 703 pixels
    Height : 576 pixels
    Clean aperture height : 576 pixels
    Display aspect ratio : 4:3
    Clean aperture display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Scan type : Interlaced
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 6.637
    Stream size : 3.53 GiB (92%)
    Writing library : AJA Kona Hardware
    Language : English
    Encoded date : UTC 2021-08-26 22:59:29
    Tagged date : UTC 2021-08-26 22:59:29
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio #1
    Format : PCM
    Format settings : Little / Signed
    Codec ID : sowt
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 80.7 MiB (2%)
    Language : English
    1) As I want to capture the Analogue data from the HI8 tape at the best quality (but possibly not RAW due to the HUGE file size), would there be much visible difference in RAW verses Pro Res HQ?
    2) Is Pro Res HQ the best codec / option to use for HI8 tape capture or should I consider better quality version of Pro Res when capturing ?
    3) Once taking the captured Pro Res HQ video in to Adobe premier and editing etc. when I choose to export the final edited video, under the export (Media) video settings in adobe, I am choosing match clip setting, i.e. the original captured file (Pro Res HQ) video setting/format
    so in theory adobe premier has matched video rendering settings to the source file when exporting the final video
    using this export template, will there be any loss in video quality in the final exported file or should it be equal to the source file in quality ?
    4) when I export as above and use medio info I notice a difference of the bit rate
    original is constant and exported is variable
    5) does this mater ? can I make adobe premier export constant bit rate ?
    Here is the Adobe rendered Output File, I assuming the quality will be 100% the same as the source HI8 captured file from my AJA Kona ??
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2005.03 (qt )
    File size : 4.30 GiB
    Duration : 8 min 48 s
    Overall bit rate : 70.0 Mb/s
    Encoded date : UTC 2021-08-29 14:11:09
    Tagged date : UTC 2021-08-29 14:11:35
    Writing library : Apple QuickTime
    TIM : 00:00:00:00
    TSC : 25
    TSZ : 1
    Video
    Format : ProRes
    Codec ID : apch
    Bit rate mode : Variable
    Bit rate : 68.5 Mb/s
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bits/(Pixel*Frame) : 6.603
    Stream size : 4.21 GiB (98%)
    Writing library : adb0
    Language : English
    Tagged date : UTC 2021-08-29 14:11:09
    Audio
    Format : PCM
    Codec ID : sowt
    Channel layout : L R
    Bit depth : 16 bits
    Stream size : 96.7 MiB (2%)
    Language : English
    INTERLACING --- Wil l Lose Any Original Video Quality Converting Interlaced to Progressive ?? Should I Keep The Exported Final Video To Interlaced ?
    6) the original clip is interlace ok for TVs not so good for digital playback ?
    there is an option in adobe premiere export setting to change export to progressive
    when I have tried this I think the exported file is no longer interlaced as when I disable interlacing in vlc player there are no horrible interlacing lines
    7) Now my question is, should I leave Interlacing On when exporting final video from premier ??
    8) will there be video loss in quality exporting progressive over original interlaced
    playback on pc seem better progressive, but don't want to lose any original capture quality from the Hi8 Tape
    should there be anything else I should do in adobe premier or settings I should check for
    Appreciate any help as just want to archive the old tape the best way with maximum acceptable quality
    Thanks in advance for any help
    Yes, lots.
    Retain interlaced version for archive.
    Create deinterlaced copy for using on streaming websites.
    Apr 2010
    London
    Thanks for the info
    but could someone please answer the questions about editing files in Adobe Premier
    If I import a video file in Apple Pro Res HQ
    Then Trim
    and then export Apple Pro Res HQ
    will there be any video loss in quality or should the exported file be the same as the original file
  4. Member DB83's Avatar
    Jul 2007
    Since your topic title does not really describe your core issue, I suggest you edit it. (Think you can do that from the initial post)
    Some like "Q re Adobe Premier and Apple Pro Res"
    If not, contact forum admin and ask them to edit the title with your chosen words.
    Apr 2010
    London
    thanks for the suggestion of title change
  6. Member Cornucopia's Avatar
    Rule: with lossy codecs (not counting lossless suboptions), there is ALWAYS loss with every re-encoding generation. How much depends on the quality of the existing source, the codec, and the settings including the bitrate. Hard to say other than that, but ProRes is already considered a near-lossless codec, so unless you do something odd/wrong/stupid, your loss should be minimal.
  7. If you're just doing cuts type editing, PP can smart render prores (use to be only Macs , but even the PC version can now) . Smart render means it basically stream copies, so no loss. You have to make sure all the settings match correctly in the source and export settings. On other sections that you do other things like effects, layers, overlays etc.. it will re-encode those sections so minimal quality loss because you're re-encoding prores to prores
    Apr 2010
    London
    Thanks for the replies, appreciated
    how do you know premier pro is using smart render prores ?? when rendering out?
    as the prores 442 hq files out of premier pro are always smaller in size than my source pro res 442 hq ??? so would not imagine premier pro has matched the source file quality when saving ?
  9. If any of the settings are mismatched, it forces re-encoding.
    eg. If source was TFF, but you left interlace off, and encoded progressive, that's different , it will cause a re-encode
    But in general - indirectly you can tell in PP smart rendering is working with all supported smart render formats, because it's very fast compared to re-rendering and re-encoding.
    But if you want to be 100% certain, you do a quality test on and in/out test - the export compared to the import , such as PSNR . Anything other than infinity means it's not lossless, and it's not smart rendering
  10. Originally Posted by Johnnysh View Post
    But is that with editing, cutting out segments? Or just an in/out test ?
    Is audio the same ?
    If you do PSNR test , it will confirm if it was smart rendered (or not)
    ffmpeg -i "export.mov" -i "source.mov" -lavfi  "[0:v]settb=1/AVTB,setpts=PTS-STARTPTS[main];[1:v]settb=1/AVTB,setpts=PTS-STARTPTS[ref];[main][ref]psnr" -f null -
    If it's lossless and smart rendered it will say something like this
    [Parsed_psnr_4 @ 00000089198c7680] PSNR y:inf u:inf v:inf average:inf min:inf max:inf
