I was cursing the latest version of VLC player (3.0.16). Out of the box, on full-range videos, it was changing grays of 235-235-235 to 255-255-255, and changing 16-16-16 to 0-0-0.
After some poking around I found the cure:
Tools -> Preferences -> Video (icons at top of screen)
Output: Direct3D9 video output
I have a full-range test pattern consisting of four gray patches of 0, 16, 235 and 255. After applying the above fix I get correct levels on the test pattern.
I also get correct levels without adjustment on VirtualDub2. You can actually see separation between the 235 and 255 patches. This should be helpful if you are doing critical video work.
Results 1 to 1 of 1
MPEG 2 Extension for VLC? (VLC can't play its own recordings?!?!)
By gastrof in forum Newbie / General discussionsReplies: 17Last Post: 17th Dec 2018, 00:06 -
VLC cannot play MPEG-2 (.mpg) file (VLC cannot identify the audio or ...)
By Jeppe in forum Software PlayingReplies: 6Last Post: 30th Jan 2018, 20:47 -
Android:i want to play this channel in vlc android application (vlc.apk)
By sam jack in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2017, 17:10 -
Configuring correct Levels for GPU driver-> HDMI->Monitor
By chummy02 in forum ComputerReplies: 3Last Post: 14th Jul 2017, 16:04 -
How the "see" correct BT.709 color using VLC in a PC?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2017, 11:57
