Hi everyone,
As I am new of this forum and I'm having problems loading my bluray into multiAVCHD 4.1
My original BLURAY disc its only about 40GIG and when I load in multiAVCHD 4.1 its turn out to be 78GIG
Does anyone have the same problem like myself
or this software is getting too old or I need to used something else, please advise
Does anyone know any software that its similar to multiAVCHD 4.1 ? all I want to do is load the orginal bluay disc and add in another extra audio of my language
I hope you guys can help me on this
and thank you so much for your kind help
Cheers
Sometimes multiAVCHD states an incorrect size for the compilation. If the original disc is 40gb then the compilation also will be 40gb + the size of the extra language track. I suggest that you just process it with the additional language track and then see what size the processed files actually occupy. Note though that if you want to burn it unchanged other than by the addition of another language track you will need a dual layer bdr blank for recording.
Multiavchd chapters
By Dustin7ca in forum AudioReplies: 0Last Post: 17th Feb 2019, 13:45 -
multiAVCHD menu
By pepegot1 in forum EditingReplies: 0Last Post: 25th Oct 2018, 18:09 -
MultiAVCHD transcode 4:3 --> 16:9?
By Ennio in forum Video ConversionReplies: 1Last Post: 24th Jun 2018, 07:16 -
Menu help with multiAVCHD
By RoyGBiv-inRI in forum Authoring (Blu-ray)Replies: 0Last Post: 25th Sep 2017, 12:14 -
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 17:18
