hey...i just got a new movie (Spider-Man) and it's in avi format...but i dont know what it's encoded to...so can i encode it to VCD and play it on my standalone DVD player? or will it probably be a waste of my time to try?
ok...lol i got it to work. but when i play it in my DVD player the sound skips around alittle. is there any way to fix this? (i'm using the panasonic MPEG1 Encoder 2.5) and the movie is really dark...any way to brighten it up alittle?
--thanks for your help so far!!!
--Mike -
Panasonic doesnt like to decode anything - so make sure you converted the audio stream to WAV first before you feed it into Panasonic
also panasonic is not good for resizing - you might have cut off a ton of your movie without knowing it -- use VirtualDub for your resize first
frameserve from VirtualDub - within VirtualDub you can fix a lot of problems (including darkness) -- It's too long for me to explain here so do a bit of research on VirtualDub frameserving - it's not very hard, honest
also - get the ctp-sm version of spider man in SVCD -- a little birdy told me that version LOOKS AMAZINGyour pal,
Stinky -
ok...thanks. and where did that little birdy get the ctp-sm version of spider man? (m7d7g7@msn.com)Originally Posted by Stinky
--thanks abunch!
--Mike -
could that little birdy tell me where he found his? (gohan812@angelfire.com)
the one I found is messed up
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41
