I have some .wmv files. They import and work fine in AviUtl using Windows 7. But when I import them under Windows 10, the audio is all out of sync. In both cases, W7 and W10, I drag-n-drop the file into the advanced editing window. Then it creates the index file. I choose match imported video for the project. In Windows 10 the audio is playing from some other part of the file. Way off. I have not figured out from where in the file the audio is playing. It is not just a simple 2 second delay or something like that. As best as I know.
I can import a file and just try playing it. No edits at all. And the audio is off. Any way to fix this?
Results 1 to 14 of 14
Thanks. That did not work but it points me at a problem. My media players do not play the .avi version. They all play the .wmv version. VLC player just gave an error for missing codec. Windows Media Player played but with no audio. Pot Player said it needs WMA pro codec. I let Pot Player grab a codec but it still did not play. (Maybe I have to reboot) I do not see a way to get that WMA pro codec. It is paid only? I also did the test using Windows 7 with the same result.
These are from Pot Player
This is the original .wmv file:
General
Complete name : J:\- Editing\Original Videos\Stage 13 A.wmv
Format : Windows Media
File size : 2.52 GiB
Duration : 1 h 0 min
Overall bit rate mode : Constant
Overall bit rate : 6 002 kb/s
Maximum Overall bit rate : 6 048 kb/s
Movie name : maxJAV.com
Album : maxJAV.com
Performer : maxJAV.com / maxJAV.com
Composer : maxJAV.com
Encoded by : maxJAV.com
Genre : maxJAV.com
Encoded date : UTC 2011-04-07 16:36:19.906
Copyright : maxJAV.com
Comment : maxJAV.com
Rating : 5
WM/OriginalArtist : maxJAV.com
WM/URL : maxJAV.com
WM/UserWebURL : maxJAV.com
WM/CodedBy : maxJAV.com
WM/Lyrics : maxJAV.com
WM/SharedUserRating : 99
Author/Url : maxJAV.com
WM/ItunesPodcastURL : maxJAV.com
WM/TitleSortOrder : maxJAV.com
WM/Show : maxJAV.com
ID3 : (Binary)
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Description of the codec : Windows Media Video 9 Advanced Profile
Bit rate mode : Constant
Bit rate : 5 744 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.092
Stream size : 2.41 GiB (96%)
Audio
Format : WMA
Format profile : Pro
Codec ID : 162
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 10 Professional - 256 kbps, 44 kHz, 2 channel 16 bit (A/V) 1-pass CBR
Bit rate : 256 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Bit depth : 16 bits
Stream size : 110 MiB (4%)
This is from the .avi version:
General
Complete name : J:\- Editing\Original Videos\Stage 13 A.avi
Format : AVI
File size : 2.51 GiB
Overall bit rate : 5 980 kb/s
Video
Format : VC-1
Codec ID : WVC1
Bit rate : 5 716 kb/s
Bit depth : 8 bits
Stream size : 2.40 GiB (96%)
Audio
Format : WMA
Codec ID : 162
Bit rate : 256 kb/s
Bit depth : 16 bits
Interleave, duration : 186 ms (5.58 video frames)
This is the error message for the .avi version:
Built-in AVI Source::Audio 1
"WMA Pro" audio decoder is required to play the file.
Media Type 0:
Audio: WMA Pro 44100Hz 2.0 chn 256 kbps
[AM_MEDIA_TYPE]
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {00000162-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 12000
cbFormat: 18
[WAVEFORMATEX]
wFormatTag: 0x0162
nChannels: 2
nSamplesPerSec: 44100
nAvgBytesPerSec: 32004
nBlockAlign: 1
wBitsPerSample: 16
cbSize: 0
pbFormat:
0000: 62 01 02 00 44 ac 00 00 04 7d 00 00 01 00 10 00 b...DŽ...}......
0010: 00 00 .. -
I have a vague memory of having to add the WMA codec to my Windows 7, years ago. Methinks that is why it works on W7 but not W10.
I found a workaround. Using Avidemux I copied the video but recompressed the audio to AAC(FDK) to an mkv format. Now AviUtl will play it properly. I will try some edits soon. Any hints on the best audio to remux to using Avidemux? It probably does not matter much which one.
EDIT: Nope, this solution does not work. If I cut the video in the "wrong" place, the output is not encoded properly. Some combination of the Video and audio codecs seems to be the problem. I can try other audio encoders in Avidemux but I will wait for a hint of which one to try. I don't want to test them all.
I still want to add the WMA 10 pro codec or maybe an importer to AviUtl that supports that codec.Last edited by ChasVideo; 27th Aug 2021 at 23:11.
That did not work either. The video still breaks up within AviUtl as I move the position slider around. An edit point breaks up in the output file.
Looks like I can:
Find the codec that will work.
Only edit in Windows 7. Not sure why it works OK there.
Re-encode the video and audio to something that will work. Maybe .mp4. Probably using Avidemux. I hate re-encoding more than needed. -
Perhaps try Virtualdub2. Assuming it successfully opens the source, set Video/Compression to FFmpeg FFV1 (lossless code),
configure, bit depth 8, YUV 4:2:0,
file/save video/save as AVI
Then hope that AviUtil can open it properly -
Thanks for your help. But it was my fault. I did not install the latest AviUtl. I copied the "portable" one from my Windows 7. Now I can Edit that file. It does have an audio delay of about -233 ms within AviUtl. No idea why. The file plays fine in all the players I have tried. The AviUtl audio delay filter seems to be working. I just have to fine tune it to get it exact.
Just updating in case some one needs this info someday. That still did not work. The audio delay was different every time. Sometimes the audio delay filter did not even adjust anything.
I played with avidemux which can copy video and only recode audio. But it can only output to an .mkv or .avi file with wmv video without compressing. I tried all combinations. Using mp3 for the audio worked the best. But ... AviUtl seemed to get confused with wmv video within an avi file. As I move the slider around the video breaks up. It has to find a key frame to play again. The audio was in sync but editing would be a real pain.
After getting pissed and throwing the mouse at the cat (it liked that) and the monitor at the dog (it did not like that) I finally remembered something.
VLC player can recode. VLC can recode just audio and can output a real .wmv file. It can recode audio into wma2 which is a valid codec for a .wmv file. That worked. Finally. The new .wmv files work well. The same as they did with my Windows 7.Last edited by ChasVideo; 29th Aug 2021 at 17:32. Reason: Fixed FLV to VLC
"Programmers are human-shaped machines that transform alcohol into bugs."
Importing miniDV tapes onto Mac. Video Ok but Audio is not Importing
By JontheScott in forum MacReplies: 5Last Post: 14th Jun 2021, 20:24 -
wmv to mov (conversion via Windows), easy & free?
By BlankCanvas in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2021, 02:48 -
Canon ZR950 mini dv importing into IMovie recording problem
By Fishn1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2018, 14:24 -
Aviutil
By foldbck123 in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2017, 11:28 -
Problem after upgrading windows
By oliver5087 in forum ComputerReplies: 3Last Post: 3rd Sep 2017, 17:23
