Results 1 to 16 of 16
    Oct 2015
    Toronto, Canada
    Hello,
    I've used the following script to frameserve from Vegas/Magix to VDub for years with the purpose of doubling the frame rate
    Setmemorymax(512)
    SetMTMode(3,8)
    PluginPath = "C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\"
    LoadPlugin(PluginPath+"svpflow1.dll")
    LoadPlugin(PluginPath+"svpflow2.dll")
    Import(PluginPath+"InterFrame2.avsi")
    AVISource("H:\Stuff\test.avi", audio=false).ConvertToYV12()
    SetMTMode(2)
    #deinterlace
    #crop
    #denoise
    #resize
    InterFrame(Cores=8, GPU=true)
    I am now looking for a script that will do nothing but allow for a passthrough to VDub, without any filter applied in the conversion so that I can use VDub's filters like changing the ratio or apply a deinterlace and then render it out of VDub.
    Is there a way to adapt this script to do just that or would you suggest something else entirely? I have no idea how to code...
  2. Put # at the beginning of each line (or delete the line), keep only the one with "avisource...". That's all.
  3. Code:
    Add ConvertToYV12() if you need it.
    Oct 2015
    Toronto, Canada
    Thank you both.
    Why would I need to convert to YV12 again?
  5. My script doesn't include the ConvertToYV12(). Hence, you have to add it if you need it.
    Oct 2015
    Toronto, Canada
    If I just keep that line it doesn't work. I get an error:
    Avisynth open failure
    AVISource autodetect: couldn't open file H:\Stuff\test.avi
    Error code: 2
    (E:\Stuff\60FPS-Copy.avs, line 7)
    If I try to open the file with the original script it works fine.
  7. Maybe it has something to to with MEGUI's private version of AviSynth. Try keeping the PluginPath line too:
    Remove the ConvertToYV12() if you don't need it.
    Oct 2015
    Toronto, Canada
    It's gone. All that's left is this:
  9. Originally Posted by philvideofilm View Post
    Error code: 2
    But that says you have 7 or more lines in your script. VirtualDub is still evaluating wrong script.
    Oct 2015
    Toronto, Canada
    That was before I removed everything save the AVISource line. It is still the same error message but now it says "line1"
  11. Did you put the pluginpath back in like I suggested?
    The script with just AviSource would normally work in AviSynth -- I use such scripts all the time. But there may be something about MeGUI that requires the pluginpath be set.
  12. And what does error message say now?
    Oct 2015
    Toronto, Canada
    Error code: 2
    (E:\Stuff\60FPS-Copy.avs, line 1)
    I open the original 60FPS.avs and the test.avi loads correctly. Only when I try to open the 60FPS-Copy.avs do I get the error. I've even moved the functioning script to another folder and rename the 60FPS-Copy to 60FPS and I still get the error message. If I try to open the original script that I moved to another folder it works fine. I don't know squat about programming but this is mystifying.
    Mar 2008
    There is some confusion about whether it is e:\stuff or h:\stuff
    Is test.avi actually in h:\stuff. Which version of Windows is this ?
  15. Originally Posted by philvideofilm View Post
    If you're not using avisynth for any filters/transforms - why do you need an avs script at all ? vdub can open the signpost avi file directly
    Oct 2015
    Toronto, Canada
    Of course, of course, the path. The equivalent of "is it plugged into the electrical outlet"
    MASSIVE slapping of my forehead now.
    Thanks, it's all good now.
